Question about Westinghouse Microwave Ovens
Westinghouse freestyle oven 678
Element is touching bottom and burned out
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Not sure how to take
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
SOURCE: i have a westinghouse oven freestyle 662 and i was
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Posted on Feb 19, 2011
Daniel S
  • 4323 Answers
SOURCE: there are dribbles behind the
Hi
Please check this video and follow the step by step instructions to clean/replace it:
Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 22, 2011
  • 1833 Answers
SOURCE: moved into house with westinghouse
This problem can arise due to the following
1. The is not powered on
2. Gas valve is not turned on (for gas oven)
3. Clock is not set.
I am assuming that the first 2 problems are resolve by you already. For clock setting you have follow the following steps.
1. Press the "mode" button until the "clock" indicator begins flashing.
2. Press the - or + buttons to change the time. 5 seconds after the last change, the "clock" indicator will disappear, confirming the time has been set.
I am sure the problem is in clock setting. Please refer to your user manual for other clock settings. Note that without setting the clock properly the oven will not start.
Posted on Aug 12, 2011
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
I have a kitchenaid 27 oven and microwave combo, the bottom element burned out. I replaced it but it doesn't heat up. Any help. Ty.
When it burned out, it may have also shorted out, so you should check to see if there is a fuse in the circuit to the element.
Aug 23, 2014 | Microwave Ovens
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
Dryer is over heating, all thermo have been replaced along with motor and belt. Turn on and still shuts down and smells like its burning. Dryer is hot to touch.
dryer element is fused to metal housing thereby heating all the time as the element is grounded all the time making a closed circuit
Apr 17, 2009 | Maytag MMV4205 Microwave Oven
Not sure how to take the glass off the front of the oven for cleaning on my Westinghouse Freestyle 688...
Sep 03, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
