Question about Vehicle Parts & Accessories
On a 2000 4x4 escalade the abs light is on, speedometer flickering and the dears not shifting correctly what can be the problem?
  • Lee Collier
    Lee Collier Feb 10, 2014
    does the Escalade have any codes ? Also hows is it running? Is the speedometer flicking while run? Does it flicker with key on engine off?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
You may want to replace the Vehicle . speed sensor!
Posted on Mar 05, 2014
Have a hard fault code P0500
According to http://repairpal.com/OBD-II-Code-P0500:
Vehicle Speed Sensor Malfunction
Symptoms
  • Check Engine Light will illuminate
  • Vehicle may not shift properly
  • Speedometer may not operate correctly
  • In some cases, there are no adverse conditions noticed by the driver
  • In some cases, there may be performance problems and/or shifting problems.
  • Other warning lights may come on such as the ABS light and Traction Control light.
Common Problems That Trigger the P0500 Code
  • Defective Vehicle Speed Sensor
  • Defective Speedometer
  • Vehicle Speed Sensor wiring or connector
  • Communication (CAN) bus problems
  • Defective transmission or differential Vehicle Speed Sensor drive gear
Common Misdiagnoses
  • Speedomter problem
  • Internal Transmission problem
  • ABS/Traction Control probelm
  • Driveline problem
Mar 27, 2015 | BMW 325i Cars & Trucks
Abs light on,brake light on,speedometer not working,trans won't shift
Is the break pedal stiff? with the ABS light on and the break light on sounds like your breaks might be locked or locking up which could be why the transmission isn't shifting
Sep 14, 2013 | Chevrolet Cars & Trucks
I have a 99 escalade and the abs light is on and speedometers or trip is not working also will not let you drive over ten mp before light comes on and your unable to drive
Need to have a shop check for codes & diagnose the issue
Somewhere between the speed sensor & abs sensors you have a problem
Aug 11, 2013 | Cars & Trucks
I cranked my 2000 dodge ram 1500 and the abs and brake indicators came on and the speedometer is not working but the truck is running fine.
Check fuses. The speedometer works off electronic signals, it is common for several indicators, like the brake light and abs signal to work off the same fuse. Check your owners manual for fuse panel location and fuse identification. Don't be surprised if you experience strange transmission shifting while this fuse is out as well. Without the speedometer signal the transmission doesn't know when to shift properly.
Sep 08, 2010 | Dodge Ram 1500 Cars & Trucks
SPEEDOMETER WILL NOT WORK AND ABS LIGHT AND PARKING BRAKE LIGHT ARE ON .
Change the speed sensor in the top of the rear differential
Aug 23, 2009 | 1999 Dodge Ram
Truck will ot shift and speedometer stopped working too
Have somebody check for trouble codes.Look for possible speed sensor codes.The speed sensor is a input to both trans and abs.
Aug 06, 2009 | 1998 GMC Sierra
Transmission doesnt shift abs & brake light on speedometer doesnt work
I had the same problem with ABS light and speedometer, I was told that it is the transmission control module. It has not yet stopped shifting but I have had times where it just wont stay running. It will start and then stall. Hope this helps.
May 11, 2009 | 2008 Dodge Ram Pickup 1500
ABS,Brake light "on" and speedometer not working correctly
Rear Sensor replacement 44.95 retail
Shop Labor 60.00
This will fix the ABS and Brake lights, will fix the speedometer isue and smooth out the erratic shifting.
Aug 05, 2008 | 2000 Dodge Durango
Abs brake light on wont shift until speedometer starts working
Could be your Speed sensor that would make the abs light come on because its not sensing the speed you are traveling. I have no Idea why when your gas gauge is on empty it won't shift. May be its the speed sensor and it was just happened to do it right when you where on empty. Does the speedometer work right or is it erratic? Let me Know this sound like and interesting problem I would like to work on and trouble shoot. Your ECM may be going too. There is so much going on Its hard to tell. But I would make sure the speed sensor is working properly first, Ok Talk at you soon. Thanks Bear001... Oh Yeah make sure all fluids are up and in good condition
Jun 17, 2008 | 1998 Dodge Durango
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
