Question about Numark Industries Numark KMX02
No video from left deck
After not being used for about 6 months, the left player plays the audio but not the video from CDG discs. The right one performs properly. Tachnically, how does the slider switch the video between the players ? What could be causing this problem ? Are there any outhorized service providers in Ontario for Newmark products, preferrably near Ottawa, Canada ?
How do I connect my laptop to my numark icdmix3
If you want to mixdown onto your laptop, get a cable with RCA left and right on one end and an 1/8 headphone jack on the other. On the back is a master out w/left + right and go to line in or mic input on laptop. If you don't have a line in, you have to disable the mic signal +4 db setting in control panel/audio properties volume control. Open properties there and add mic volume control, and open advanced to turn off +4db setting.
Mar 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Cdg not playing disk
Can you hear the disk spinning? If not, the motor may need replacement.
If it is spinning- is it on Pause? If it is spinning and not on pause, the laser my be burned out, or the flat ribbon connector may be dislodged.
Apr 01, 2012 | American Audio Cdg-350 Professional Dual...
Hi! I can not open the left tray on my CDG 350 player.
If the unit is still within warranty, then it should be returned for repair by the manufacturer. If not, and you are handy with a screwdriver, then you may be able to fix it yourself.
Although I am not familiar with this precise model, in my experience most units of this type are based on standard optical drives, just like in a PC. If you remove the front panel of the unit, you should be able to find the emergency release hole: a small hole just wide enough to push a straightened paper clip into, which should release the drawer.
Hope this helps.
Sep 23, 2011 | American Audio Cdg-350 Professional Dual...
My player shows the disc but when I press play it goes to 1: 00 the cdg will not play
If the disc is "homemade", some players will NOT read the disc. If this is NOT the problem, it is unlikely anything internal would be a DIY repair.
Sep 06, 2011 | RSQ NK 2000U
Hi, There is a problem on my CDMP 6000 left player pitch control. When pitch control is switched on and adjusted to +/-, it does not get set at that value but keeps fluctuating. Also, the pitch control...
You MAY have contamination in the slider.You could try putting a little CRC226 into the slot and work the control. Use ONLY this product CRC226 available at Home Depot in the electrical dept/
Apr 30, 2011 | Gemini Sound Products Gemini Cdmp-6000...
When i plug in my mp3 into the phonic system it doesnt play certain notes of songs and there is no bass
It sounds like the cables you are using, or the way you have it wired into the system are not correct. If you are using the stereo channels on the mixer, then the system also needs to be wired in stereo to the proper amp and speakers. Otherwise you hear the left or right side of the stereo mix, and not all of the music correctly.
Another problem may be the kind of cables you are using to wire the MP3 player to the mixer with. If you are using a 1/8" adapter to the MP3 player, make sure it is a STEREO 1/8" adapter, and that both left and right channels are plugged into the mixer, preferably on the first two inputs to test and see that both channels are indeed coming through. Then you may move them to a stereo channel. Again, make sure that the system is wire in stereo in order to hear both sides, Good Luck
Mar 23, 2011 | Phonic Am240d Compact Audio Mixer W/...
KARAOKE MACHINE PLAYS SOUND BUT NOT WORDS
I assume you know that you MUST use special Karaoke disks to have lyrics displayed... Ordinary music CD's do not have that data on them.
Jan 25, 2011 | American Audio Cdg-350 Professional Dual...
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Nov 27, 2010 | Gemini Sound Products Gemini Cdmp-6000...
Numark Industries Numark KMX02 Logo
15 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
