Question about Metra 1993-94 Lexus Ls400 Stereo/radio Dash Kit Combo 99-8156
Stereo dash kit - Metra 1993-94 Lexus Ls400 Stereo/radio Dash Kit Combo 99-8156
How me installin a new radio
Buy wiring kit and radio dash kit from parts store for the paticuliar vehicle remove old radio, splice wires from new stereo to wiring kit, they should be color coded, install radio dash kit plug in wiring harness slide stereo into dash and enjoy
Nov 06, 2013 | 2000 Dodge Caravan
Tip
How to install Radio in Honda Accord
Things You'll Need:
* Stereo
* Wiring harness
* Dash kit
* Phillips screwdriver
* Heat shrink
* Lighter
* Wire strippers
* Wire caps
In order to install A Radio first follow steps of Removing the Factory Radio
#1
Open the center console, and you'll see two phillips screws at the bottom. Unscrew both of them.
#2
Remove the drink tray, and unscrew three more phillips screws. The center console is now loose enough to move.
#3
Pull the center console back a few inches to expose two more screws under the plastic part of the gear shift. Remove these screws.
#4
Pull the ashtray out of the dash, and you'll see one more phillips screw. Remove this screw and pull off the plastic panel around the factory stereo.
#5
Locate the metal tray under the factory pocket (below the stereo), and pull it out of the dash. There will be two phillips screws holding it in place; remove those, and then pull the stereo out of the dash. You'll need to unplug the wiring harness that is plugged into the back of the radio.
Now Install The New Stereo
#1
Assemble the dash kit, as shown in the instructions. Put it into the dash where you just took the stereo out. There will be a rectangular opening, and a pocket underneath. The opening is where the radio will go.
#2
Secure the dash kit by screwing in the one screw in the ash tray, and the two in the opening of the panel.
#3
Insert the metal cage that came with the stereo into the opening above the pocket. Ensure that the fit is flush with the pocket. Using a screwdriver, bend the metal tabs upward, which holds the metal cage in place.
#4
Start wiring the stereo harness to the wiring harness. Match wires color by color until all of the wires are paired. For example, if you find a purple wire coming out of the aftermarket wiring harness, plug it into a purple wire from the factory harness. You aren't touching any of the wires in your dash on this step, you are simply wiring the new stereo to the wiring harness.
To connect these wires you'll want to place a piece of heat shrink over one of the wires, strip the ends, twist both ends together, and then pull the heat shrink over the exposed metal parts of the two wires. Heat the heat shrink with a lighter until it shrinks and forms a tight bond between the two wires. When done correctly, you won't be able to pull the wires apart.
#5
Plug the aftermarket harness into the factory plug, and insert the radio back into the dash. If you find wires that don't have a match, be sure to cap them so that the ends aren't exposed. Exposed wires are what cause shorts and electrical problems.
#6
Work in reverse order to put the dash back together. The radio won't be secure in the dash until the dash is put back together.
Hope this helps
Thanks
on Oct 07, 2010 | Honda Accord Cars & Trucks
Installing aftermarket stereo
Should just need the New stereo and the items that come in the box with it.
Sep 06, 2013 | Acura Cars & Trucks
How do you put normal cd player in 2004 model ford fusion
You will need an adapter kit for the dash panel specific for the Fusion or a multi kit, both availible at an Auto Parts store. You should also buy the wiring harness for the Car as well, this will make life much easier on you! Connect the harness to the stereo, following the schematic/diagram. Pop the dash panel apart and remove the old stereo. Slide the adapter plate over the wires FIRST, then connect the wire harness, put the adapter plate in place and then slide the stereo in place, re-assemble the dash...
Jun 11, 2012 | 2006 Ford Fusion
Need to know how to install my deck in my 1999 chevy suburban
The best way to install an aftermarket stereo is to go to a stereo installation store and get the in dash "metra" kit and the wiring harness adapter that allows you to connect the aftermarket stereo wiring to the factory wiring on the truck...the "metra" kit adapts the aftermarket radio to fit into the space for your particualar vehicle..the tech at the stereo store will know what all this means if they know what they are doing...To clarify, "metra" is a brand name for these kits andthey also go by the name scoshe...
Jan 11, 2011 | Alpine CDE-7872 CD Player
I need instructions on how to install an after market stereo in a 2006 Ford Fusion SEL.
Buy a metra dash kit and it will have step by step instructions,you will need harness too ,donot cut factory wires.!!!!!!!
Jun 03, 2010 | 2006 Ford Fusion
97 lexus stereo has no read out cannot tell what
best buy sells a kit where u can install a aftermarket stereo in your car youll need a mount kit and a wiring harness
Jan 18, 2010 | Car Audio & Video
After market stereo installation help
You'll an stereo install kit. I comes with the surround for the new stereo to fit into, and that will fit into the space for the stereo in the dash, this kit will also have a connector to wire the new stereo to, and plug into the stock stereo plugs.
Jan 03, 2010 | Sony CDX-CA400 CD Player
How can i replace the manufacture radio in my car and replace it with aftermarket car stereo
You best bet, because of a warranty, is to have a professional shop install your stereo. But if you are like all of us guru's here, you like to get your hands dirty.
First you need to remove the dash around your factory stereo. Be patient here and try not to break any of the dash. You may need to remove screws and pop loose plastic retainers located on the backside of the dash.
Wire the after market stereo to the harness located below by maching the colors provided. Thank the stereo companies for making this simple. Use crimp connectors or solder your connections, which ever best suits you. Tape up any remaining wires with eectrical to minimize the chance of a short.
Take the metal sleeve provided by the sereo you choose and install it into the install kit located below. Once you have removed the factory stereo, test fit the install kit and attach any tabs neccessary provided by the kit.
Now take the aftermarket stereo and place into the sleeve you installe din the install kit until it clicks into its locks. Now, the harness you wired up earlier, plug it into the factory harness and then into you stereo. Hook up the antenna, you may need to purchase a antenna adapter. Now before you install the stereo, do a test run to make sure everything is working. Once you are content that it is all working, install the new stereo and then reverse the steps in removing the dash panel and stereo.
Below are pictures of the needed hardware:
Sep 14, 2009 | 2003 Pontiac Vibe
Need a dash installation kit for a 3.5" screen in-dash stereo.
You can find that at a walmart or a local car audio shop. Depending on the make and model of your vehicle will decide wether it is in stock or not. Good luck.
-Andrew Hawkins
Apr 10, 2008 | iLO XM-MP3-CD Car Stereo
Metra 1993-94 Lexus Ls400 Stereo/radio Dash Kit Combo 99-8156 Logo
13 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
