Question about Black & Decker Bread Machine
Wont go through cycle properly - Black & Decker Bread Machine
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
My washer wont go into spin cycle. I hear a clicking sound coming from the timer. It still wont work. What could it be? Any more suggestions, Huseyin?
if it is not progressing to the spin cycle it could be the controller is faulty
I suggest an technician call to get the proper diagnosis for the problem
Jun 22, 2015 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Spin cycle not working properly
What is the model number of the unit?
Nov 07, 2012 | Washing Machines
I have a high efficiency maytag washer. I interrupted the cycle before it was finished in the rinse and spin and now it wont work properly.l tried to get it to just spin again, but it wanted to fill with...
Thanks for choosing FixYa and welcome to the site. Looking at what you said, I would advise you to make sure that the timing is set correct. You want to make sure it is on cycle one. You can try to unplug it and see if that will reset it correctly. The timing may be stuck in spin cycle. The switch may be defective. If you have any questions, feel free to ask.
Apr 10, 2011 | Washing Machines
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Oven wont unlock after self clean cycle
Make sure you're getting 220 to the stove, maybe one breaker is off or bad.
Apr 21, 2009 | Whirlpool GR460 Electric Kitchen Range
Black & Decker Bread Machine Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
