Question about Sony VAIO VGNFS Series VGNFS3B VGNFS15GP VGNFS18GP (610074349099)
CPU is running very slowly on all applications, reset to factory settings. I am running trend security package.. could I be out of ram 512meg?
    Habit-Forming:
    New Friend:
  • 164 Answers
First disable the antivirus and then upgrade your ram to atleast 1 gb.
Posted on Feb 11, 2014
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Freezing
A computer/notebook/laptop can freeze due to a lot of reasons. Here are few noteworthy ones. Check them and see if they help, if not then post a little detail of when it freezes more etc:
a) Antivirus programs have a great tendency of eating up memory quite quickly. So, get a lightweight antivirus program like Microsoft Security Essentials or Avast etc.
b) If you have a low RAM then it is recommended that you run very few applications at the background. Avoid running any unnecessary applications.
c) If you have a desktop set with lots of transitions and effects it can cause huge RAM and often results in freezing of system.
d) Your O/S could be a problem too. If the above things doesn't help try resetting/re-installing the O/S and hopefully it shall help you a lot.
e) Check your system for any viral activities. You can perform an online scan using many free online scanners like Trend Micro etc.
Oct 24, 2012 | Acer Aspire 3620 Laptop/notebook
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
I have a Foxconn n15235 motherboard and i have installed a 2 gig ddr2 memory but it only registers as 1 gig,could you please help...
how many modules compatible are the ram modules the same type/brand some motherboards will not accept more than one type
also make sure the ram modules are securely seated with no dust in the sockets
The purpose of RAM is to allow your CPU faster access to programs. If your CPU had to go to the Hard Drive anytime it wanted a program your computer would run very, very slowly. So for example, when you boot your system up a significant ammount of ram is designated to your devices needed to boot up your operating system video graphics
The primary role of RAM is to copy the operating system in to itself and then load the Operating System so that you can work RAM is only used to run any desktop base applications, such as games, Microsoft Word applications, games such as desktop games and pc games, and browser based so any programs you have loading at start up will be needed by computers RAM
http://majorgeeks.com/download.php?det=1670
Freeware app that defragments and frees up your system's RAM.
Freeware application to free and optimize your computer's RAM (Random Access Memory), resulting in an increase in system performance and productivity. Automatically configures itself for ease of use and also features advanced options and customizability. FreeRAM XP Pro has been designed to be easy to use yet highly customizable by computer novices and experts alike.
hope this helps you
Sep 10, 2011 | Foxconn P4M800P7MA-RS2 Motherboard
My compaq presario v5000 runs so slow and i wanted to return it to factory settings to see if that helps thank you.
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Sep 06, 2011 | Computers & Internet
I got a 1 gig pc4200 533 mhz and system only reads half can not explain whats wrong
The purpose of RAM is to allow your CPU faster access to programs. If your CPU had to go to the Hard Drive anytime it wanted a program your computer would run very, very slowly. So for example, when you boot your system up a significant ammount of ram is designated to your devices needed to boot up your operating system video graphics the primary role of RAM is to copy the operating system in to itself and then load the Operating System so that you can work
hope this helps you
Aug 30, 2011 | MSI PM8M-V Motherboard
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
Help Finding The Best CPU For P4SD-VX Motherboard.
Brilliant, I commend you! I've posted using the simple CPU-Z program to several people on here, and they just don't seem to get it!
Sony doesn't release detailed info on their motherboards, for the most part. Just the usual generic info.
2.6 Volts?
Open CPU-Z again. CPU tab.
Let's see if you have this processor.
Name: Pentium 4 HT 2.6C
Code Name: Northwood
Package: Socket 478
Technology: 130nm
Core Speed: 2600.0MHz (Fluctuates when the computer is running)
Multiplier: 13X (Fluctuates when the computer is running. When the Core Speed fluctuates enough, the multiplier changes to match)
Bus Speed: 200.0MHz
Rated FSB: 800.0MHz
Voltage: 1.475 to 1.525 V (Fluctuates)
Click on the Mainboard tab.
Is the motherboard chipset Intel 865PE?
[Chipset: Intel i865PE
Southbridge: ICH5 or ICH5R
Motherboard made by Asus?
It may not have an Auto CPU feature in BIOS Setup then. Means you cannot just put any old processor in there. Have you been into your BIOS Setup yet?
SPD stands for Serial Presence Detect. This is used by BIOS to automatically detect what ram memory is being used, and the ram memory timings.
JEDEC was Joint Electron Device Engineering Council/s. Changed to JEDEC Solid State Technology Association.
One of the things they have done is to set standards for Ram Memory.
Voltages used and ram timings.
JEDEC 1 is the ram memory module, in Slot 1 on your computer.
(May state DIMM 1 on the motherboard)
JEDEC 2 is the ram memory module, (Stick) in Slot 2.
JEDEC set the voltage standard for DDR Sdram ram memory, at 2.5 Volts. Your computer has DDR Sdram ram memory in it.
The default voltage setting from the factory will be 2.5 volts for your computer.
Nov 16, 2009 | Office Equipment & Supplies
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Sony VAIO VGNFS Series VGNFS3B VGNFS15GP VGNFS18GP (610074349099) Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
