Question about Texas Instruments TI-30XA Calculator
How do I convert square roots (for example square root of 147) into a number like 7 over square root 3. is it possible to do that? Or can the TI-130Xa only convert perfect squares (like square root o
How to convert square roots?
  • Texas Instru... Master
  • 7,993 Answers
Unfortunately this calculator does not display results in radical form. If you enter SQRT(147) you get 12.12435565...
What you are asking for is called rationalizing an irrational expression. Usually one tries to get rid of radicals that appear in the denominators. Here is an example.
Suppose you have 1/(c+SQRT(d)), and you want to get rid of the radical in the denominator. How to do it?
Recall the identity (a-b)*(a+b)= a^2-b^2. It is true for any a and b
Rationalizing a denominator (usual case)
Now consider (c+SQRT(d)). Multiply it by (c-SQRT(d))
[c+SQRT(d)]*[c-SQRT(d)]=c^2 -[SQRT(d)]^2=c^2-d
You see that there is no radical.
Now take 1/(c+SQRT(d)). To get rid of the radical from the denominator multiply it by (c-SQRT(d)). But to leave the value of your expression 1/(c+SQRT(d)) unchanged, you must multiply both numerator and denominator by (c-SQRT(d)).
The numerator becomes 1*(c-SQRT(d))=c-SQRT(d), and the denominator (c^2-d).
Finally, the rationalized form of the expression 1/(c+SQRT(d)) is
[c-SQRT(d)]/[c^2-d].
Rationalizing a numerator
Sometimes, people have a radical in the numerator that they want to get rid of and have it in the denominator. The procedure is the same
Example:(c+SQRT(d)), the denominator here is 1
(c+SQRT(d))=(c+SQRT(d))*[c-SQRT(d)]/[c-SQRT(d)]. This gives
[c^2-d]/[c-SQRT(d)]
You have no radical in the numerator but there is one in the denominator. This is called rationalizing the numerator.
Your case is a lot simpler
SQRT(147)=7*SQRT(3)
Multiply it by SQRT(3)/SQRT(3) which is 1. This gives
SQRT(147)=7*3/SQRT(3)=21/SQRT(3)
SQRT(147)= 21/SQRT(3)
Posted on Feb 09, 2014
SOURCE: Trig Problem
U cant.
Posted on Feb 27, 2008
  • 718 Answers
SOURCE: square roots
One way is you get square root by raising to the (1/2) power. For example square root of 16 is
16^(1/2).
You can use this method to get the other "roots" as well e.g. 1/3, 1/4, etc.
Posted on Apr 18, 2009
  • 7993 Answers
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
  • 7993 Answers
SOURCE: how do you tak the square root of 64 or the 4 root of any other #
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
5. To extract the squqre root of a number you can use the key on the 3rd line [root x] or the general power key on line 6 with exponent 1/2
Exemple square root of 256
256 [Root x] [EXE] should give you 16
256 [Y to x] (1/2) [EXE] should give you 16 also
Hope that helps.
Posted on Nov 08, 2009
  • 8 Answers
SOURCE: How do you use the imaginary number with the TI-84 calculator?
If you want the answer in rectangular form, set MODE a+bi and tap ENTER and QUIT. Tap square root sign, tap (-)4 and close the parenthesis and tap ENTER. The answer is shown as 2i.
If you want the answer in polar form, set MODE to re^xi and and DEGREE. Tap ENTER and QUIT. Tap the square root sign, tap (-)4, close the parenthesis, and tap ENTER. The answer shown is 2e^90i. (2 at ninety degrees). If you selected RADIAN mode, the answer would be 2e^1.57i (2 at 1.57 radians; or 2 at pi/2 radians)
Posted on Dec 20, 2009
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
Feb 03, 2015 | Casio fx-115ES Plus Scientific Calculator
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
Jan 17, 2013 | Casio FX-9860GII Graphing Calculator With...
How can you use the square root key to find the square root number?
Press 2nd [square-root], enter the number, press ) =
For example, to calculate the square root of 5, press 2nd [square-root] 5 ) =
May 07, 2011 | Texas Instruments TI-30 XIIS Calculator
Have TI30xIIS calculator. How do I find square root of a number. For example, the square root of 9. Where is the square root? I know 3 is the square root of 9, but how do I do this on calculator. ...
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
Feb 16, 2011 | Texas Instruments TI-30 XIIS Calculator
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Finding the square root
Use the square-root function, which is the shifted function of the x^2 key just to the left of the 7 key.
For example, to find the square root of 2, press 2nd [square-root] 2 ) =
Nov 23, 2010 | Texas Instruments TI-30 XIIS Calculator
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
Sep 22, 2010 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
190 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
