Question about HP Tablets & eReaders
Broken screen on hp envy x2 - HP Tablets & eReaders
I have been using wi-fi printing on Samsung Galaxy 8.4 Tablet & now I'm unable to get my tablet to print.
Your printer may have changed it's IP address. This is a common occurrence on wireless networks. You should be able to get the new IP (to configure your tablet) by doing this on your printer: Go to the Home Screen --> Setup, then touch Reports and then select Network Configuration to see all of the printer's network details.
Mar 16, 2016 | HP Tablets & eReaders
How do i get my samsung tablet to work on my envy laptop
you can use the pairing programme if its on your mobile
Jun 29, 2015 | Samsung Tablets & eReaders
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Screen doesnt work in some areas for touch and pen
    Connector is probably loose, remove battery, under that is a small casing, remove that, check the SMALLER of the two connectors, if loose, plug back in, if broken, give up as it won't work unless you buy a new MOBO
    Jun 16, 2010 | HP Pavilion TX2000Z Tablet PC
    Pls help me my hp tablet stopes displaying
    If it turns on but theres nothing on the screen, I bet the screen is broken. Id suggest you to take it to repair.
    Aug 09, 2009 | Tablets & eReaders
    HP tablet PC tc4200 latch fixable?
    In a pinch, you can pop the lid open on these by sliding a credit card between the screen and base chassis. Typically when the latch breaks on a tc4200/4400 it will need to be replaced unless it is simply jammed.
    Aug 05, 2008 | Compaq tc4200 Tablet PC
    Display crack
    Honestly it may cost less just buying a new laptop. Screens can cost more than a new laptop =[
    You can use an external monitor if you do not plan on moving the laptop around too much.
    G'luck
    Jun 05, 2008 | HP Pavilion TX1320US Tablet PC
    Tablets & eReaders Logo
    11 people viewed this question
    Top HP Tablets & eReaders Experts
    Anthony Pattay
    Level 1 Expert
    Lawrence Oravetz
    Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
