Question about Panasonic Pt-Vx400 4000 Ansi Lumens Xga Projector
Projector vx400 is shutting off itself - Panasonic Pt-Vx400 4000 Ansi Lumens Xga Projector
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Firmware update
We regret to inform you all firmware updates must be performed by authorized service centers.
Apr 08, 2014 | Panasonic PT-VX400 Projector PT-VX400
Firmware update pt-vx400
I don't believe that there is a 'User' update firmware file available, the only thing I could find was this site which gives you all you can download. That is unless you have members access to "Panasonic Projector Extranet" which is for resellers (i think). Best to contact Panasonic directly or a Panasonic Main Dealer who may be able to eith send you the firmware via email or update your device for a small fee?
PT VW330 VX400 VX400NT
Apr 08, 2014 | Panasonic Office Equipment & Supplies
Reset lamp for Panasonic PT-vx400
There should be a menu that goes across the top listing video, audio, setup, projection....etc. Either under setup or advanced there will be a drop down menu with lamp settings under it. Under that menu will be a reset lamp or something as direct as lamp hours. That is where you can reset the lamp timer.
Feb 05, 2013 | Panasonic PT-VX400 Projector PT-VX400
How do you cool down the system after a presentation?
hi,
To cool down the projector after use just press the Standby button and leave it in standby mode. The projector itself will cool down and will shut down itself. Only after this remove the power.
ok
Mar 19, 2011 | Sharp PG-A20X Multimedia Projector
HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Aug 02, 2010 | Optoma HD20 DLP Projector
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Panasonic Pt-Vx400 4000 Ansi Lumens Xga Projector Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
