Question about Ovens
How do i set the clock on a simpson evolution 844 multi function oven
We had a black out and now we cant use the oven because the clock isnt set any more
SOURCE: Simpson Evolution 906 Fan forced oven
have you solved it?
John
Posted on Aug 29, 2009
SOURCE: Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Posted on Dec 07, 2009
  • 5 Answers
SOURCE: How do I set clock on Belling Synergie
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Posted on Mar 29, 2010
  • 250 Answers
SOURCE: Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on May 29, 2010
SOURCE: how do you change light
The glass cover definitely unscrews anti-clockwise, but mine was impossible to start moving by hand. I used a pair of adjustable pliers and while the glass cover is made out of pretty thick glass, I didn't want to be squeezing it so I set the pliers jaws to exactly the same width as the glass cover. Because the glass cover has 4 bumps set around it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're looking for a replacement, keep in mind that it has to be a max of 25W.
Posted on Dec 27, 2010
Can you tell me the light bulb type/size and how to change it please?
Refer your question to a local appliance parts supplier or an Evolution dealer/supplier.
Jun 07, 2016 | Ovens
I have a simpson evolution 904 oven and the wiring diagram has been lost , would you have a copy
LOOK UP ON LINE TYPE IN SIMPSON EVOLUTION 904 WIRING DIAGRAM SEE IF YOU CAN FIND ONE THAT WAY. IF NOT TRY THE LIBRARY.
Jan 28, 2015 | Ovens
How do I set the clock
our algor oven clock keeps making a noise all the time and we cant find out how to stop it in our manual
Jan 04, 2013 | Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
How to set the clock on Westinghouse Virtuoso 70 oven
hello im not sure how to set the clock on my oven move in my houe 4 mnths ago and i cant bake in it unless i turn the grill on so would u please tell me how to set the time thankyou Sylvana
Nov 30, 2009 | Ovens
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
