How to connect topfield 2100 to Sony bravia
Cannot get hdmi to work after enable button press
fkuk
  • 311 Answers
SOURCE: HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Posted on Sep 10, 2007
  • 79 Answers
SOURCE: Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
Posted on May 01, 2008
SOURCE: hdmi
Bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "S H Pos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standby button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Mar 30, 2009
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
  • 94 Answers
SOURCE: I have connected my Charter HDTV settop box to the
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Posted on Sep 26, 2009
Why wont my humax connect to my Dennon amp via the hdmi my old foxstat one does
This might be due to having one of the following enabled on the Denon:
AOC - E-Link
Hitachi - HDMI-CEC
LG - SimpLink
Onkyo - RIHD (Remote Interactive over HDMI)
Panasonic - Viera Link
Philips - EasyLink
Pioneer - Kuro Link
Samsung - Anynet+
Sharp - Aquos Link
Sony - Bravia Link & Bravia
Toshiba - CE-Link & Regza Link
Mitsubishi - NetCommand
Oct 13, 2015 | Humax Televison & Video
Philips blu ray bdp2205, no picture when connecting to Sony bravia via HDMI cable. Works on other TV just fine. Help!
Make sure that your input on your Bravia is selected to the HDMI input that you are connected to; and that HDMI video output is enabled. If after doing that you still do not have picture from it then try another HDMI input.
Dec 29, 2014 | Televison & Video
Sony bravia tv problems
1. Turn off the TV and unplug all the HDMI connections to the TV.
2. Turn on the TV and while holding down the up arrow on the remote control, press the power button.
3. The TV will turn itself off, then back on again then release the up arrow button
4. Complete the initial TV setup wizard
5. Turn off the TV and plug back in all the HDMI cables.
6. Check to see if the inputs are working.
Hope this helps.
Dec 31, 2013 | Televison & Video
I have a new Sony Bravia LCD TV 40" EX500. That I need to hook external speakers to thru an ONKYO amp. The amp has optical and coaxial Audio in but NOT HDMI. I have connected the optical Audio...
Well, one of the solutions would be a universal remote control.
The way amplifiers usually work is such that the volume needs to be adjusted on the amplifier and not the source (TV in your case).
If you can give me more information on the model of your amp I might be able to prove die you with another solution.
Feb 17, 2011 | Televison & Video
I have a Sony bravia 32" (KLV-32T400A) and have just bought an xbox.. On trying to connect it using the HDMI input an error comes up saying that it's not a supported signal. I also tried plugging my laptop...
All hd-ready tv's only support max 1080i and not 1080p. The default setting on the Xbox is 1080p, that's why you get that message. There is a way to fix this, just follow the steps below:
Connect TV and X box via HDMI cable with units switched off.
Switch both units on.
  1. Press the right arrow 7 times (Left top jog knob on game controller)
  2. Press "A" button 4 times (Green button)
  3. Press "up" arrow once to set to 1080i
  4. Press "up" arrow once again to set to 720p.
  5. Press "A" to store setting
Sep 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When i connect my PS3 into the HDMI on Sony Bravia TV nothing works
Is it working when you connect it with the regular cables? when it does then the HDMI cable is at fault.
Jun 11, 2010 | Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Jan 15, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Dec 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hope that helps!
May 01, 2008 | Televison & Video
13 people viewed this question
 Grubhead
Grubhead
