Question about Dell V525w Wireless All In One Inkjet Printer
Printed images have lines through them
Large printed images have yellow horizontal lines. Have deep cleaned printer head, aligned the printer head, updated software and replaced cartridges.
  • 76 Answers
SOURCE: cartridge alignment
So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
Ajkill
  • 2035 Answers
SOURCE: white horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Posted on Mar 21, 2008
SOURCE: Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Posted on Apr 18, 2008
  • 326 Answers
SOURCE: Cleaning printer heads
go to your start menu/settings/printers and faxes,right click on your printer and go to printer preferences and to your maintinence tab. youll be able to clean your heads from there. just to warn you might have to keep cleaning untill it runs clear and it does use a lot of your ink.
hope it helps
Posted on Jul 21, 2008
SOURCE: poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Posted on Aug 19, 2008
Canon Pixma MP620 problem. It prints with a thick white lines going horizontally, so that the texts are faded out and not legible.
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
A horizontal line appears on prints every 9/32 of an inch, especially on lighter prints
The following a step by step instructions for the printer issue:
Confirm the ink tank(s) are properly installed
Perform print head alignment
Perform Print Head Cleaning - iP4500
If the prints are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleaning or print head deep cleaning. Also, you can check the cleaning results by printing the Nozzle Check Pattern after cleaning.
Remove tape from the ink tank and make sure the air hole is clear
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon Pixma iP4500 InkJet Printer
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dell V525w Wireless All In One Inkjet Printer Logo
19 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
