Question about Linksys Wireless-G WRT54G Router
Router to computer issues WRT54GS
I have a good signal from my router to my HP Pavilion laptop. Everything says it is connected and the signal is excelent.  The router seems to be working great.
My problem is that although I have a wireless conection my computer won't accept it.  The router is a WRT54GS.  My computer is running Windows XP, Home edition.  Is there something I'm missing? I've gone throuhg all the proper set up programs and etc but can't make a conection.
Any help would be greatly appericated.
Thanks in Advance
Dave
  • Jgandme2 Oct 27, 2007
    I finally got the dang thing up and running.  I didn't do anything that I haven't tried several times preavious.
    Thanks for your help.  Reading through many of the issues posted here helped as did the feedback I got.
    I have one suggestion I would like to make.  I read several posts were people complained that the WRT54GS and other routers like it, were unable to be "hung" or installed on the side of a wall or cupboard.  I put double sided taped velcro on the feet of the router to accomplish this.  You can also remove the black rubber feet on the router easily and screw them to the wall.  Simply trace around the two top feet prior to removing them  to insure the location then remove the feet and screw them down and simply push the rubber feet back on to the router.  Hope this helps someone else out with the same installation problem that I encountered.
    Thanks again for your help!
    Dave
  • 328 Answers
Ensure that any firewall you may have is turned off, then try it again.
Posted on Oct 26, 2007
I have HP Pavilion Entertainment PC and I'm currently connected to the internet via a wirelss router. My roommates are also connected to the same router and they have not had any issues with...
Try positioning your computer next to the router - or within line of sight of the router - see if the limited connectivity thing comes up. It probably won't. Then try placing your laptop at the same spot where your roommate(s) normally uses his or hers or their computers and see if that makes any difference.
Wireless signals can go thru walls, or bounce off of anything that it can't go thru - so we're all trying to catch a good bounce and hence, location matters a lot. Sometimes moving a wireless router can make a huge difference - like moving it from behind the TV to above the TV for better broadcasting (cause the signal ain't gonna go thru a TV's power supply). Anyway, that'd be how I'd go about troubleshooting this issue....
Sep 08, 2011 | Computers & Internet
I just installed a wirelss linksys wrt54gs v4 router in the bk bedroom, with my office computer equipment,,my wife has a wireless hp pavilion 6000, that she would like to use in the living room,40 ft away...
Hello
Try updating the firmware on the router.You need to log into the router using 192.168.1.0
Username =admin
password = admin or the word password.
Once in the routers home page check for updates and download and install.Also be sure any firewalls are not blocking the signal.
While your in the router set up a personal wep key for your wireless security.
There is a possibility your lossing signal to outside intruder.
Apr 21, 2011 | Linksys Wireless-G WRT54GS Router...
Everything is connected my laptop was able to find the name of my wireless but was not able to connect. I'm using windows 7 on the laptop. Any idea of what i should do to fix the problem. Everything was...
Hi. First issue why your laptop cant connect to your router is regarding witht the password. Make sure that you are typing in the correct password of your router. Check the type of authentication used e.g WPA, WEP etc. Second issue, is this the first time you used windows 7 OS in connecting to your router. There are issues in linkys routers that is not compatible with windows 7 and you need firmware upgrade for your router. You can also try to test the connectivity using a wired conncetion (LAN cable) conncet directly to your router nd se if you were able to get an internet concetion using a wired connection.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 28, 2010 | Linksys Wireless-G WRT54GS Router...
Have a dv6-136 1sb hp pavilion Entertainment pc. i am able to access the internet via wireless internet access when i am close to the router. however when i go three rooms away i get no internet access. at...
The issue here may not be the laptop but the router strength of it's wireless radio. Do you have another laptop or a freind who can come over and test his connection? The DV series laptops have pretty decent antennae and wireless cards. Try to update the drivers for the WLAN card, make sure the antennae leads have a good secure fit at the ends where they attach to the card. If the router is a couple to several years old, it may need the firmware updated.
Jul 05, 2010 | HP Pavilion dv6000z Notebook
Computer sees belkin 54g, shows all bars, when
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
Regards!
Jul 10, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Pavilion wont stay connected to internet through linksys router
without looking at laptops myself, if it's not a problem where somehow a connection got loose or built up dust and debris, then it could be a hardware issue where the pavilion wifi isn't as good as the vaio's. The same thing happens to me on my hp pavilion dv2000.
Apr 04, 2009 | HP Computers & Internet
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
I need to set up my linksys WRT54GS. do i set it up on my laptop or desktop? or both?
When you set up your router do always use a wired computer (phisically connected ).
You'll be setting up the router so setting it up through one is enough
Once the router is set up by performing these options
1>start->run->cmd ->youll find default gateway
2>open rsp by typing in default gateway address in brouser tab
3>select ->connection type ->and put in your uname and password for dsl or clone mac address for cable
4>set channell to 11 or 6 for best signal strength
5>set ur ssid(network name) and security (wep preffered) if you want it.
6>once router is set up on the top of the rsp you may see ipstatus:: connected
7>Now just select your network on your laptop
and happy surfing
Let me know if your issue is sorted
Feb 26, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
