Question about Chauvet Intimidator 1.0 Dmx-600 512 Scanners
Replacing light bulbs - Chauvet Intimidator 1.0 Dmx-600 512 Scanners
I have a Technics PR-305 Digital piano The back light is barely light when I turn on the piano Can that be replaced?
yes maybe you may fined that some of the power to the led is being blocked by causing a larger resistant to the led which will cause it not to light up as bright.
Jun 12, 2014 | Universal MCU Extension 4 x 4 16-Key...
Pilot light problem
Most power lights are line voltage, i.e. 12v power=12v lamp, 120v power=120v lamp. Get a voltmeter and see what voltage is goin' to the lamp. Once you have determined that,, 12v lamps are easily found @ auto parts stores. 120v @ Radio Shack or electronics supply stores.
Dec 29, 2013 | VOX AC30HW2X Amp Combo
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work.
The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
Dec 20, 2011 | Chauvet Intimidator 1.0 Dmx-600 512...
The light on my Ashdown mag 300 combo input level does not light up. How easy is it to fix. Electronic places charge 85.00 just for a quote and 85.00 and hour plus parts to fix it. HELP!.
If you mean the light in the meter, those can be hard to replace and mosts shops would replace the meter itself which would up the cost. It is probably a 12 or 14 volt bulb(s). Look at the back of the meter and see if there is a removable socket to get at the bulb... if not, then the bulb(s) is internal and probably a soldered in grain of wheat bulb(s). If you have never worked on meters before it takes GREAT care to keep contamination out when working on them. I would certainly not pay $85 to have bulbs replaced... use an external lamp if you really need to seee the meter... one of the little LED ones would work.
Sep 12, 2011 | Ashdown MAG C115-300 Combo Bass Amp
Brake lights are not working on my 1996 chevy s-10 pick-up
check if all brake lights are not working or not , if only one of em is faulty then its time to replace the bulbs . Else its just a blown fuse. Check users manual to find how to replace a fuse .
Thank you .
Jun 01, 2011 | Eminence Speaker Eminence PX:BULB...
My Eliminator E-144 runs but won't light up. I have replaced the bulbs, replaced the fuse, the fan runs, the sensitivity dial and mic work, it spins but the bulbs won't light up?
A very common problem with the small Halogen lamps at this power level is the socket contacts burn up and no longer contact the lamp pins. Check the resistance between teh slip rings (lift one brush as the motor will be in the circuit if you don't) and look for a real low resitance since you have 6000 watts of bulbs, they will draw 5 amps total when running so they are about 24 ohms hot and since incandescents are about 1/10 that when cold expect around 2.4 ohms or so. Make sure you do not handle the glass of the bulbs. I have found sockets if yours are bad at an online source as
http://www.divinelighting.com/round-multibase-socket-g4-g53-gy635-lamp-holder-p-263.html
Check which base your bulbs have though as I replace other lamps here and this may be different than yours.
May 02, 2011 | Eliminator E144 Mini Double Derby Dj Club...
I purchased this light in August of 2010. By November of 201, the bulbs began to flicker off and on. I replaced them with new bulbs and the same thing is happening. Is there something I can do to get this...
VERY COMMON problem of the bi-pin Halogen lamps... The SOCKETS are subject to very high heat and lose the temper of the spring contacts which heat, oxidize and fail. It is a FATAL thing with the sockets. They have to be replaced.
Here one source for sockets... remember to get one for your particular lamp... this link is for a particular base so you may have to go to the home of this company.
http://www.frontierlighting.com/product.jsp?part=44766&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c44766
ALSO search Ebay for "socket XXXX" where XXXX is the lamp number.
Feb 28, 2011 | Chauvet Ch-258 Cyborg Light Lighting...
How do I replace a fender 2 x 2 deville pilot light? CL
You unscrew the plastic dome over the bulb. The bukb is a bayonet base. Push in and turn... probably counterclockwise and extract the bulb. Replace by reversing the process.
Use T47 or #47 (6 volt) lamp... available at Radio SHack and other places.
Jan 23, 2011 | Fender R) Hot Rod DeVille III 212 Guitar...
The followspot was on and the bulb blew with a loud bang, when I changed the bulb it powered up and came on but could no longer blackout or dim the light with the dimmer manually or DMX. I have it apart...
When he bulb blew out, it temporarily shorted and blew out the Triac that controls the voltage to the lamp. It will need to be replaced... A lot of the Chauvet units use a 16 amp, 600 volt Triac part number :
BTA16-600BRG
which is available from Digikey. It will be mounted on a heatsink.
Aug 23, 2010 | Chauvet Followspot 400g with Stand
Have 2 Chauvet Intimidator Spots. 1 no longer projects light and the bulb is not the issue. It powers up, goes thur its start up routine but will not light the bulb
This unit got a 24volt lamps that came from a transformer. Usually the ceramic contact of the lamp get damaged and corroded after some time and can be replace. You should test at the same time that the voltage is allright with a multimeter. Most sound shop keep such ceramic in stock because its always broken....
Aug 10, 2009 | Chauvet Followspot 400g with Stand
Chauvet Intimidator 1.0 Dmx-600 512 Scanners Logo
16 people viewed this question
Top Chauvet Music Experts
Vito Vacirca Jr.
Are you a Chauvet Music Expert? Answer questions, earn points and help others
