Meos tv model no meo-dvd192b
Using remote or manual.to switch on 240v.red light on tv.press green goes to green.goes back to red no pic
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
  • 3 Answers
SOURCE: My RCA model D52W20 will not fully power on when
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Posted on Mar 24, 2009
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 3 Answers
SOURCE: I have bought a MEOS tv/dvd/freeview combo in
Meos dvd154B I just bought and returned as the DVD/CD did not work. Having just read the other reports, I wish I had seen this site earlier. Has anyone had good results from this unit?
Posted on Oct 26, 2009
SOURCE: Meos GPS Navigation Module with UK+EURO Maps haw
iF U CANT GET TIME TO CHANGE TO SAME TIME AS THE HEAD UNIT. IN THE SATNAVE SOFTWARE U NEED TO GO TO MENU / GPS HARDWARE/ SYNC TIME. THIS WILL SET THE SATNAV TIME TO SAME AS HEAD UNIT SO SET IT FIRST
Posted on Aug 11, 2010
I have a meo-dvd tv.when plugged in the green light comes on and nothing else happens.The on/off button on the tv and remote dont work.Any ideas.Thanks.
there is a possibility of the power supply having issues get it checked and I would recomend replacement of capacitors especially the big ones
May 18, 2017 | Televison & Video
I have a 2 year old Meos 192B TV. It works perfectly on 220V but not on 12V. What could the problem be?
I suspect there is not enough power to run the TV. Does it work in your vehicle with the supplied power lead.
Jan 31, 2017 | Televison & Video
Meos MC702B
Should be a standard connector from a car suppliers hobby shop.
https://www.youtube.com/watch?v=YQ-bd5MgSRE
Sep 05, 2017 | Computers & Internet
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
Does anyone know where i can buy the meos naveme 120 gps navigation module for my meos mc702b?
I am looking for one of these as well. Maybe, if they're discontinued we could buy a couple cheap!
Jul 24, 2012 | GPS
I have a meos mc701b coupled to a meos navme120 and i cant get the satnav to work it just keeps flashing up the same message "no signal" any ideas
Go to GPS hardware and select "locate" then try the different port options - it will be on one of them - problem solved.
Jun 27, 2010 | Car Audio & Video
Need the remote code for a meos dvd121b 12.1 portable tv / dvd player as the one that came with the unit is very small and would like to use bigger multi function device. regards - Graham
What's the remote code for the meos DVD 121b 12.1 portable tv/ DVD player. The buttons on that remote seem to freeze when I'm using the freeview don't know why buttons that dont work in freeview are here are some of them the setup button channel change and epg button this is with the remote control I use.
Feb 28, 2010 | Televison & Video
Dec 14, 2009 | GPS
Recording on the Meos 20'' LCD-DVD Combo 2009 model
YOU CANT RECORD FROM A SCART TO USB, THE SCART IS IN ONLY AND ANALOGUE. YOU SHOULD HAVE A USB PORT ON THE TV TO PLUG IN YOUR STICK OR PORTABLE HARD DRIVE
Aug 31, 2009 | Televison & Video
I have bought a MEOS tv/dvd/freeview combo in December. The DVD player jammed in January scoring the DVD's, they sent a replacement unit. A very similar problem happened with the replacement unit at the...
Mar 26, 2009 | Televison & Video
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
