Question about Whirlpool Dryers
How to stop off the beeping for whirlpool model WED5600XW1
This model beeps when you turn the knob for ANY setting and whenever you start the dryer. I would like to turn it off.
  • 32 Answers
SOURCE: Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Posted on Sep 29, 2008
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
SOURCE: dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Posted on Apr 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
Can anyone assist with this problem - the power goes on but no buttons work at all. They either beep fast or shut the entire dryer off. Also, the setting light on the main knob is always blinking now...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
After choosing dryer cycle by turning the selection knob, I try to start cycle by pressing big Start button. It beeps several fast beeps. Also the drum light just stopped coming on.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Whirlpool GEW9250 Electric Dryer
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
TIMER NOT WORKING
The knob does not pull out on dryers. Turn the timer to the desired setting and push the start button. Eric
Sep 10, 2009 | Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
