Question about Yamaha AVENTAGE RX-A3030 AV Receiver BONUS PAK w/ HDMI Cables & Headphones
I have a Yamaha RX-A3030 and when I first turn it on to watch pay TV it switches the audio input to audio 1 instead of the set top box feed. When I go into the pop up menu and change the input from auto to hdmi its fine until I turn the amp off, but when I switch it back on after a prolonged period it goes back to its previous auto set up which I think is being confused by the arc hdmi function? Very frustrating, any idea?
4 Suggested Answers
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
SOURCE: Every time I turn my Yamaha RX-V565 on it switches
Set your TV, Sattellite receiver and audio where you want it when you turn on the set. Then hit the Scene button named "TV" and hold it down till the yamaha receiver says set complete and it will turn on to HDMI 2
Posted on Mar 26, 2010
  • 482 Answers
SOURCE: yamaha rx-v367 and internet tv audio
try connecting the hdmi out from cable box to your tv hdmi input, and leave the hdmi out from tv to the reciever where it is, leaving reciever selected to 'TV' and yes, a sub matters (it is not part of your problem but you need the bass a sub provides)
Posted on Mar 06, 2013
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
I need help putting my surround sound to my tv .dvd and x box
2 ways to do this
if your tv has multiple inputs and an audio output its easy if not there is a way but its more complicated
if your dvd and xbox have HDMI (link to inexpensive hdmi cables) outputs pick up some cables on ebay and use that to go directly to the TV then use the audio output of the Tv and run it to any input on your receiver EXCEPT PHONO. I use video 1 since its easy to remember.
all you do is set your receiver to video 1 and then set your tv to the input you want to watch ie: video 1 for xbox, video 2 for the dvd
this will also work if you use component inputs on your tv (the red, green blue ones)
Now the harder way to do it.
Your receiver has high def (red, blue, green) component inputs
plug your dvd, xbox and cable box if you have one into the 3 video inputs on your receiver and teh TV audio can be plugged into the CD or aux input.
here is the issue.
running both the audio and VIDEO signal through the receiver may degrade your video quality based on the type of video processor that your receiver has.
secondly lets say your dvd doesn't have component outputs and you have to run s-video cable instead then you have to run multiple monitor outputs to your tv as the receiver wil not "upconvert or downconvert" the signal from one format to the other.
Newer higher end receivers will do the conversion but usually not until you get into the $500 and up price point.
when i do installs I try to ,ake it so that people have to push the fewest amount of buttons. Most people know how to switch the input on the TV but then get confused if they have to also start switching inputs on secondary devices such as receivers
hope that helps
Feb 19, 2010 | Yamaha RX-V461 AV Receiver
Every time I turn my Yamaha RX-V565 on it switches to the AV1 input instead of staying on the HDMI input that it was on when I turned it off.
Feb 01, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Jun 05, 2009 | Yamaha RX-V463 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Yamaha AVENTAGE RX-A3030 AV Receiver BONUS PAK w/ HDMI Cables & Headphones Logo
24 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
