Question about Panasonic Computers & Internet
Setup menu will not display
Setup menu does not display when the setup button is hit - DMR-PWT530 BD/DVD Recorder.
SOURCE: Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Posted on Dec 27, 2006
SOURCE: remote problem
flip open the door on the remote and press setup and 1 at the same time . this will switch it back to DR-1
Posted on Jan 08, 2008
Ajkill
  • 2035 Answers
SOURCE: remote control code
The remote control for your DVR has the capability to control 2 additional DVRs in addition to the one that you currently have. In order for the remote control to work with your DVR, you will need to make certain both of them are talking on the same frequency. If you press the remote control and the front of your unit says DR2, that means that you need to have your remote on DR2 as well so that it can operate the DVR. To set your remote to DR2, you will need to make sure the unit is off then you will need to press and hold down the SETUP button and while you are holding this button down, press the number 2 button. Your remote is now set to DR2.
Good luck...
Posted on Sep 07, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: Panasonic DMR-EZ27 displays RC1 code
Pressing the 1 and the enter button at the same time worked for me too! Thanks!
Posted on Nov 22, 2008
Panasonic DMR-PWT530 Setup Menu won't display
You may have to restore original factory settings.
Feb 09, 2014 | Panasonic Televison & Video
DVD recorder DMR-E20 will not communicate with remote
Have the remote tested, it can be done easily without the unit, also most digital cameras in a very very dark room can be used--point remote at camera (with it on) and press buttons, you should see a tiny flash on the display screen of the camera.
If the remote tests good the remote receiver in the unit it operates may be bad.
Attached is a typical receiver, yours may not have the metal bracket and the item in the picture is actually less than 1/2 inch tall.
Dec 21, 2012 | Panasonic DMR-E20 DVD Recorder
I got a panasonic dmr-e100h and cant change the language to english. It came with japanise language menu
Derived from p.54 of the owners manual
Press [SETUP] to show menus
Select "Display" (6th line down or 2nd from bottom)
Select "Language" (2nd line down)
Complete owners manual @:
http://service.us.panasonic.com/OPERMANPDF/DMRE100H.PDF
Sep 15, 2010 | Panasonic DMR-E100HS DVD Recorder
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
I have tried tuning in my dvd recorder in the reset menu, but after the scan process a message appears "Check aerial connection. Help, what am I doing wrong?
make sure aerial is in dvd recorder press functions move down to others press enter move down to setup and enter highlight tuning move right and down to auto setup reset and enter
tou will see a warning message move to yes and enter the dvd recorder will start tuning and a list of all the stations that been found will be displayed after that it will start to scan for analog stations( BEEN TURNED OFF) once finished
picture will be displayed
if no list was seen when tuning in digital stations then make sure dvd is digital
and to check aerial put direct in to didgtal tv and retune tv
Dec 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-e85 locked up. I finally got it to
To setup your IR Blaster (transmitter), hold down the channel up and down button at the same time on you the unit for more than 5 second until the unit says bye and 12:00 flashes, then power on unit and the setup screen will come on your TV.
Sep 15, 2009 | Panasonic DMR-E85H DVD Recorder
Remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Jul 24, 2009 | Panasonic DMR-ES10 DVD Recorder
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EH75VS
On the EH50, you have to go into Setup Display Front Display and change it to Bright or Dim. Automatic turns it off when power is off
Jan 13, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Setup menu
Ok I've just found out how to get the interlaced/progressive problem sorted out. It is as follows and PLEASE REMEMBER you will be doing this "Blind" sice the screen is black:
1. Power on the DVD unit.
2..Press the "SET UP" button on the remote, ONCE (DVD Display should show "Setup" )
3. Using the arrow buttons on the remote, push the RIGHT arrow ">" ONCE
4..Press the "DOWN" Arrow on the remote ONCE
5. Press the "ENTER" button on the remote ONCE
6. Press the "DOWN" Arrow on the remote ONCE
7. Press the "ENTER" Button on the remote ONCE
At this point you should have your picture and menu displayed on the screen, simply hit setup again to exit, and get the hell out of there!
If you want a copy of what you should be looking for, e mailed, I can do that.
Finally, to do a system restore, which will achive the same results (but you'll have to reset date, time etc.), follow steps 1 & 2 Then instead of hitting the DOWN arrow once, press it THREE times and hit "ENTER" this will restore the unit to factory settings. I have never done this so I am only guesing what other settings you will have to adjust, as well as time and date.
I also have the details on how to make the unit region free, email me and I'll send them to you.
Good Luck!
Dec 14, 2007 | Protron PD-DVR100 DVD Recorder
Computers & Internet Logo
24 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
