Question about Yamaha MG32/14FX 32-Input, 14-Bus Mixer w/ Dual DSP $150 Gift Card
Yamaha mg32/14fx mixer dead audio channel how to fix
4 Suggested Answers
tech48
  • 624 Answers
SOURCE: Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
Posted on Jun 30, 2008
  • 899 Answers
SOURCE: Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32 http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/mg12_4fxe.pdf
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
Posted on Mar 31, 2009
  • 3107 Answers
SOURCE: My 16 channel Yamaha mixer board will not power on as if power switch is messed up I'm wondering if there is an easy fix
It depends. If if has an external power supply, you can try a different supply of the same rating. Beyond that, it may be a blown fuse, which may be internal on the power supply board, or as you say perhaps a broken power switch. Whether it's easy or not will depend on your diagnostic skills, how much you know about electronic repairs, and your availability of parts.
Generally, i suggest people take their repairs to professionals as poking around inside electronic gear can cause more damage, both to the gear and to themselves.
Posted on Apr 29, 2016
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Channels 1 and 2 on a Yamaha MG166cx-USB mixer seem to be burned out. They aren't working. Other channels are fine. Any idea what the issue could be?
Get the schematics. ALSO, MANY TIMES IT IS AN ISSUE OF THE INSERT JACKS BECOMING DIRTY ! Spray some cleaner and plug/unplug a plug (sic) several times. That has saved me many times. Luck !
Feb 20, 2014 | Yamaha MG166CX-USB Mixer w/ Cable and...
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Signal Light Problems Yamaha P2500
Stereo amplifier = two channel..A and B.
1. Make sure that your stereo audio mixer has an output from LEFT going to amp channel A and output RIGHT going to channel B.
2. Check that the "Pan" control on your audio mixer is set to the 12:00 position.
3. Inputs to mixer...make sure the music/microphone input channels "Pan" controls are also set for 12:00 as well.
Jun 11, 2009 | Yamaha P-2500 Amplifier
Fader's problem in YAMAHA O2R96
Hi! I've got a Yamaha 01v and to auto test the faders I simply hold the ENTER button while turning on the mixer. I guess It's the same for the 02R. ;)
May 14, 2009 | Yamaha Digital Sound Projector YSP-800S -...
Mar 31, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
Jun 30, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Yamaha MG32/14FX 32-Input, 14-Bus Mixer w/ Dual DSP $150 Gift Card Logo
Top Yamaha Computers & Internet Experts
Tony
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
