Question about Dishwashers
Start/reset light flashing twice
Fisher and paykel DW691EDSS
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
reg501
  • 413 Answers
SOURCE: fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Posted on Jul 04, 2008
  • 784 Answers
SOURCE: My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Posted on Sep 12, 2009
  • 784 Answers
SOURCE: Fisher & Paykel double dishwasher bottom
F2 is indicating a fault for the motor. This motor has 2 directional operations. One direction of rotating for spraying water for washing. The other for draining at the end of washing cycle. I don't think it is a problem with the motor, but there is some food clogging up its rotation path causing this issue. Need to take out the bottom stainless steel exposing the motor to clean up. I do this some times. Just need to pay attention to remove and put things back properly. Now if you are not comfortable in doing it, then call F&P serviceman. Don't call any handyman, since without knowledge about this dishwasher a person can do more harm than good and you know who will take care of the bill. Good luck.
Posted on Dec 29, 2009
  • 3247 Answers
SOURCE: Dishwasher dial flashing F1
the flood switch at the base of the dishwasher cabinet has activated. This occurs if moisture has leaked into the base of the dishwasher.
There are several posts on the fixya.com site on causes and solutions.
If unable to find please post a comment and I am happy to guide you on this.
Posted on Feb 07, 2010
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Mar 22, 2014 | Fisher and Paykel Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
When i switch on my fisher an paykel smart drive model gw601-f, all the lights come on for a few seconds, then just the top lights flash back and forth
Hi just read your posting.Please reply back and tell me which lights are flashing.This is an Error Code and it will let me know what is wrong with your machine.On the row in which the lights are flashing ,starting from the left to right which ones are flashing,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply back with additional information on the lights and I am sure I can help you rectify this fault.
Jul 21, 2010 | Fisher and Paykel Fisher & Paykel Washer
In the fridge the setting panel green lights keep flashing fisher paykel
if you leave the door open too long it will flash a warning
close the door and make sure it is tight .
if this doesnt work , just unplug the fridge and plug back in aftera couple of seconds, this will reset the unit and should solve your flashing problem
Oct 03, 2009 | Fisher and Paykel E522BRXFD Stainless...
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
