Question about Euro-Pro KC274 5Quart Slow Cooker
Not keeping time and is blinking - Euro-Pro KC274 5Quart Slow Cooker
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
Turned on pot and power light keeps blinking. Cannot set to hours needed to cook.
Purchased a new crockpot from Hamilton Beach to resolve this issue.
Jan 01, 2010 | Rival Crock Pots & Slow Cookers
I try to set the time and temp and just keeps blinking
try to push and hold after you set the time and/or temp until it flashes the appropriate setting then stays solid
if there is a menu button.... time, hour... press till the right hour is on, min.... til the right min is on then menu or ok and either release or hold....
basiclly a process of elimination.
not sure if it will solve your issue. just giving you another option to try.
also unplug and wait 10 sec to let the slow cooker reset before you try again
let me know at sparkallen@aol.com
Dec 25, 2008 | GE Crock Pots & Slow Cookers
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
All Three Lights Blinking
We have their 6 quart Crock Pot. Same problem cited here!
We have found that, if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state. It has worked for us on several occasions so we trust it and have found no "adverse results"!
Hope this is a help to others.......
Jan 28, 2007 | Rival 38651-C 6-Quart
Euro-Pro KC274 5Quart Slow Cooker Logo
26 people viewed this question
Top Euro-Pro Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you an Euro-Pro Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
