Question about Gem Sound CDM-150 Mixer
Cd wont play
Cd is qued up but lights are flashing and wont play like its in standby
KitchenAid KSM90 mixer wont turn on, already replaced phase board
Did you play with the Brushes??? If you did you have to make sure that they went back in the correct way or they won't be touching the armature and the mixer will not operate untill the brushes touch the armature. If you did nit take the brushes out at all. then your problem is the flag connectors are not in the correct terminals. 9_15_2012_6_02_40_am.jpg
the other problem is the possibility that when you re-installed the speed board that you now have to tune the mixer by adjusting the screws on the top of the speed board.
Sep 01, 2012 | KitchenAid Food Mixers
Took out/put back black brushs/motor wont turn on
Hi TUBEARS, from what you’re describing, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 20, 2010 | KitchenAid K45SS Classic Stand Mixer
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
When i play a cd and error display shows up in the window the cd
hi My name is Jonathan but I'm DJ's that's means that When you put it an cd's on your Gemsound CD tray that is mean that it's won't played it error cd's it's might be scratch or damage and you need to ask me more about that here's the my email addresses is Jonathan_Suarez57@yahoo.com
May 13, 2009 | Gem Sound CDM-150 Mixer
Rewind and fast forward
Put the cd in when it loads and display the disc time, you can then spin the round wheels forward or backwards to the place on the song that you're playing, this only work when the song is paused or stopped. If the disc is playing the wheels are only used to slow down or speed up the song.
J Lofton(2Housepeople)
Oct 17, 2008 | Gem Sound CDM-150 Mixer
Gem Sound CDM-150 Dual cd player
This is what I did to get a copy, I went on different store sites that sold this product and I found that some will advertise the product, it's functions and its instruction manual. When you find it just copy and paste the page.
JLofton(2Housepeople)
May 21, 2008 | Gem Sound CDM-150 Mixer
KITCHEN AID MIXER WILL NOT WORK
If you have had the brushes out (under the big screws on each side) verify the cut corner of the brushes are oriented properly. Look inside the hole with a flash light and you will see where the cut corner needs to be.
Dec 31, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Gem Sound CDM-150 Mixer Logo
46 people viewed this question
Top Gem Sound Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Gem Sound Food Mixer Expert? Answer questions, earn points and help others
