Question about LG 42LC5DC 42 in. LCD Television
LG 42lc5dc service menu - LG 42LC5DC 42 in. LCD Television
I have a 2008 LG 42LC5DC. The tuner is currently set to receive a cable box feed but I'm using antennae only and want to scan over the air channels. How can I get to the setup menu?
First set the input to TV if your cable box feed didn't come in on the RF cable. Press the Input button on the side of the TV (the second button from the bottom above the Power button). Alternatively press the Input TV button on the top left of the original remote. (You'll have to search through the inputs if you have a universal remote without the feature.) Next press the Menu button on the TV or on the remote, if you have the original remote/universal remote with the matching feature. On the original remote, the Menu button is above the OK button. The Menu button is the third button from the bottom (above the Input and Power buttons). Press the Menu button and then use the Up/Down arrows to navigate to Setup. (If you use the TV buttons, the Ch Up/Down buttons are Up/Down. The volume increase and decrease buttons are Left and Right.) Press the Right arrow key and then Use the Up/Down buttons to select EZ Scan. Press the Right arrow key again. Press the Right arrow key or Enter (on the remote) to launch the scan. You can find the screen shots of the Menu options and the button locations in the manual. The manual is available here: http://www.lg.com/us/commercial/documents/32lg505h-owner-manual.pdf .
I hope this helps.
Feb 06, 2018 | LG Televison & Video
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
How can i factory reset a hotel lcd television with no factory reset opition?
You need a TV remote to select the input source from TV antenna signal.
Jul 12, 2014 | LG 42LC5DC 42 in. LCD Television
Factory reset tv model number 42LC5DC-UA
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Mar 14, 2014 | LG 42LC5DC 42 in. LCD Television
How do i access setup/screen functions?
Visit this site named 'Electro-help". Service mode entering proceedings to many brands of TVs are described there in detail. Check this link, and select the site named above. Pull up older posts there.
Jul 26, 2012 | LG 42LC5DC 42 in. LCD Television
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
How to unlock lg tv 42lc5dc (input not available)
Is there a unit pluged into the AV ports, most of the new models won't show any AV until there connected
Jan 20, 2011 | LG 42LC5DC 42 in. LCD Television
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
Jan 16, 2011 | LG Cell Phones
Lg unlocked '
If it's the childlock, you can change that in the menu.
cheers, Gerard
Nov 07, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC5DC 42 in. LCD Television Logo
175 people viewed this question
