Question about Lexmark X 264dn - multifunction Laser Printer
935.10 service Printehead Error - Lexmark X 264dn - multifunction Laser Printer
3 Suggested Answers
  • 37 Answers
SOURCE: error 935,10 service printhead error.
The printhead is the laser, tou have an error in the laser assembly (replace the laser assy).
Posted on Feb 23, 2011
Printtech
  • 1087 Answers
If this is an intermittent error, you may want to check how the printer is plugged into the wall.
Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
If still have the same issue a replacement of you printhead assembly is necessary.
For further assistance please contact Lexmark Technical Support.
Posted on Feb 27, 2012
Lexmark pro205 printehead problem
The printhead may need to be replaced. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. Contact information can be found at our website at www.lexmark.com.
If your printer is already out of warranty, you can purchase a printhead online at http://bit.ly/IZYhWo
Oct 09, 2012 | Lexmark Prospect Pro205 Wireless...
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
Error 935,10 service printhead error. e450dn
Feb 23, 2011 | Lexmark E450dn Laser Printer
My Problem for printers HP DesinkJet T1100ps Problem thish replasmet M-C printehead
Replace MC print head, ensure that before replacing the print heads, cartrige should be at least 30% ink..
Jan 23, 2011 | HP Designjet T1100ps Printer
Yellow ink not printing after cleaning utilities run; others ok
Your print head is bad. Try cleaning it with a tissue. You may see if you can find a replacement for that printehead.
May 04, 2009 | Office Equipment & Supplies
Kodak 5100 Printer Return Shipping Label
Hello C_Lopez,
As long as you receive the printhead, there's no need for you to return the defective printhead. But just to make sure, call kodak technical support: 1-800-421-6699
I hope I have been some of help...
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color printer
Is the colour cartridge new? it sounds like the yellow and purple heads could have dried out.
With my lexmark i could put the ink cartridge on a wet cloth to moisten the dried ink, then wipe it alow dried paper to remove it. However i would recommend reading your manual that came with it, or is available online before doing that. There are many different types of printehead and this method could damage it.
Also if you remove the cartride you should see some electrical contacts that line up with a cip on your cartridge, make sure all those contacts are clean.
Jun 06, 2008 | Canon i455 InkJet Photo Printer
Getting started
not sure, but try to turn printer on and off, remove and replace printehead, to see if this will work,
Mar 30, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Zebra 105se printhead issue
The controller thinks the printhead is still open. If it is open, close it.
If it's closed, it's likely that the sensor flag on the rear of the shaft has come loose and is no longer interrupting the photosensor. Remove the rear panel and inspect the flag while you move the printhead handle. The flag is supposed to be in the opening of the sensor when the printhead is closed and latched.
Steve Weinrich
LazerTek, LLC
Mar 23, 2008 | Zebra 105Se Thermal Printer
Lexmark X 264dn - multifunction   Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
