Question about Magic Bullet Nutribullet Blender
Drive cog broken - Magic Bullet Nutribullet Blender
I cannot get the blade assembly into the base of my bella cucina rocket blender?
Turn the cog in the base a little. Sometimes it gets misaligned.
Sep 24, 2014 | Bella Cucina Rocket Blender
How do I remove the black rubber rotating bit on the Kitchen Aid Blender?
My clever hubby made a spanner (piece of metal with a slot cut into it) that fits round the spine under the plastic cog and then using pliers he could just unscrew the offending piece. Use masking tape to protect the top of the blender. Thanks for previous suggestions though as it saved going to a repairer and paying unnecessary costs. Cheers.
Feb 04, 2011 | KitchenAid KSB5 Ultra Power Work Top...
Blender motor drive coupling fitted to motor which drives rotor blades broken and I want replacement.
If it is a KitchenAid blender, the part you will need is a 9704230 coupler.
Jan 29, 2010 | Blenders
Whilst blending some vegetables I accidentally knocked the glass jar which rocked it, and the small base part that is connected to the whizzer broke. Now of course it won't work at all. Can I replace the...
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
Jan 27, 2010 | KitchenAid Blenders
Blender base cog is stripped. Can it be replaced
yes you can get a new base. your best bet is to google the brand name and buy the part from the manufacturer
Aug 12, 2009 | Blenders
The black cog type gear on the bottom of the
give culinary parts unlimited a call @800 543 7549 to order a new part.they have everythinng
Jul 14, 2009 | Back to Basics Smoothie Elite Work Top...
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
CBL-10 SPARE PARTS
There is a store at Bondi Junction (Oxford street) where I purchased replacement blades as mine broke. Dont have their details though. Try tracking them down.
Dec 30, 2007 | Breville CBL10 BlendMaster Classic Work...
Magic Bullet Nutribullet Blender Logo
32 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
