Question about Crosley CR249TA Turntable
I got a crosley recrntly and it has been working great up until now. Whenever I play a song on the recprd everything works grest it is just the sound. its horrible. I thing it has something to do with the needle becauss I know its not the speakers. and also I clean it regularly so thats not the problem.
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
SOURCE: 45's won't play through
I FIGURED IT OUT! Here's how to fix the problem. 1. Remove the c clamp that holds your turntable in the box. Do this slowly so you don't over stretch or break your belt. 2. There are 3 screws holding the entire record player mechanism in the box. Take those out. 3. Look just under where the arm (the thing that holds the needle stylus) attaches to the mechanism. See that long wire rod that runs from that spot to just about the center of the turntable? It's being held at the arm by a little plastic piece that has a screw. The screw needs to be tightened. Once you tighten the screw, that will make is so that the arm has to be moved less to the right to start the record, and more to the left to turn it off. This makes it possible for you to hear the end of your songs! 4. Screw the mechanism back in the box (not too tight, you want those shock mounts to work). 5. To get the belt back on the wheel, first look under the wheel. See the big circle that is about half the size of the wheel? Place the belt around that. 6. Now look further out on the wheel. Do you see a plastic peg (actually 2 pegs....they are across from each other on the wheel)? Stretch the belt to one of the pegs. 7. Place the wheel back on the mechanism with the stretched part over the motor. Now spin the wheel slowly until the belt falls onto the motor. 8. Reattach the c clamp on the wheel and you're all set. Oh, I forgot to mention that you should put a record on and make sure you adjusted that screw under the arm enough. I had to do mine a couple of times. Hope this is helpful! Here's a video I found that better explains how to get the belt back on. http://www.youtube.com/watch?v=QaW84Z6GMVs
Posted on Dec 29, 2010
  • 23 Answers
SOURCE: I have a crosley rochester
see if you can gently straighten the handle into the proper alignment.
Posted on May 13, 2011
STYLUSCITY
  • 271 Answers
SOURCE: im looking at 2 wires with 2pin looking things
Hi, Unless there has been some kind of damage done to the cartridge iy is only the stylus that you need to replace. I have them in stock. cheers john. Styluscity@gmail.com
Posted on Aug 10, 2011
  • 34821 Answers
SOURCE: Crosley CR-49TW volume
The wires that connect to the rear of the cartridge are easy to dislodge while changing a stylus. A flashlight will help you see underneath. There are tiny little push-on connectors that attach the wires to the pins.
Posted on Sep 20, 2012
Testimonial: "They seemed attached but I pressed them together more firmly. Then I found I could open the shaft and I see that one wire of the four does not attach to anything at that point - so the problem is probably that-do you think? Now I just need to figure out how to re-attach it."
Crosley Turntable is playing too slow.
try cleaning the motor and oil with a drop of wd40 do not get it on belt
Feb 16, 2014 | Crosley RADIO CR6249-BK DELUXE KEEPSAKE...
I got a crosley recently and it has been working great up until now. Whenever I play a song on the record everything works great it is just the sound. its horrible. I think it has something to do with the...
The Needle may need replacing, if after replacing the needle and you have the same problem, it could be a connection from the needle pick up to the recever.
Feb 09, 2014 | Crosley CR249TA Turntable
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Apr 01, 2009 | Crosley Audio Players & Recorders
Cell phone freezes when i try to use my music from my memory card.
this happens sometimes. sometimes you just have to let it be frozen for a while, then it'll start working again
Oct 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Kinda frozen just weird
I got the same problem with my old sansa. All i did is return the product with the facture to the store and they gave me a new one.
Apr 26, 2008 | SanDisk Sansa e260 MP3 Player
Songs When Selected Play Something Else & Songs that are missing altogether
Follow this link - it explains how to update your player's firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Hopefully this should solve the problem. if you need the user guide find it here; http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf I Hope this helps :)
Mar 11, 2007 | SanDisk Sansa e260 MP3 Player
Crosley CR249TA Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
