Question about Philips Televison & Video
Powers on, phillips screen displays and then shuts off
Power light flashes 5 times then i turn it on and it shuts off after phillips displays. replaced main board and control board already
  • 35 Answers
Its a Fail safe. Have you checked for blown caps on the PSB-power supply board.
Posted on May 13, 2014
SOURCE: Vizio 50" P50hdm Audio with No Video
when tv is on horz trans is damge
Posted on Jul 11, 2008
SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Posted on Aug 16, 2008
SOURCE: HP 42' Plasma Won't power on, does not power up..Won't turn on
Hi i have a 42" sylvania plasma tv model 6842 pf m and have a blinking light on but it does not power on.Can you help me?
Posted on Mar 09, 2009
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
  • 70 Answers
SOURCE: Philips Magnavox 37" LCD Flat
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Posted on Jul 07, 2009
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
TV shuts off within 5 seconds of turning on
Solutions?
Hope this helps
Feb 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
