Question about Crosley CR249TA Turntable
I got a crosley recently and it has been working great up until now. Whenever I play a song on the record everything works great it is just the sound. its horrible. I think it has something to do with the needle because I know its not the speakers. and also I clean it regularly so thats not the problem. its just very scratchy and bad quality. help please!
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
The Needle may need replacing, if after replacing the needle and you have the same problem, it could be a connection from the needle pick up to the recever.
Posted on Feb 09, 2014
  • 1894 Answers
SOURCE: crosley cr249
then the recording head is facing the problems sir.
amy be small loose connection in the circuit.
if u r expert in electronics u can fix it easily
Posted on Jun 19, 2008
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
SOURCE: My Crosley combination turntable/CD/cassette/AM &
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Posted on Dec 10, 2010
SOURCE: 45's won't play through
I FIGURED IT OUT! Here's how to fix the problem. 1. Remove the c clamp that holds your turntable in the box. Do this slowly so you don't over stretch or break your belt. 2. There are 3 screws holding the entire record player mechanism in the box. Take those out. 3. Look just under where the arm (the thing that holds the needle stylus) attaches to the mechanism. See that long wire rod that runs from that spot to just about the center of the turntable? It's being held at the arm by a little plastic piece that has a screw. The screw needs to be tightened. Once you tighten the screw, that will make is so that the arm has to be moved less to the right to start the record, and more to the left to turn it off. This makes it possible for you to hear the end of your songs! 4. Screw the mechanism back in the box (not too tight, you want those shock mounts to work). 5. To get the belt back on the wheel, first look under the wheel. See the big circle that is about half the size of the wheel? Place the belt around that. 6. Now look further out on the wheel. Do you see a plastic peg (actually 2 pegs....they are across from each other on the wheel)? Stretch the belt to one of the pegs. 7. Place the wheel back on the mechanism with the stretched part over the motor. Now spin the wheel slowly until the belt falls onto the motor. 8. Reattach the c clamp on the wheel and you're all set. Oh, I forgot to mention that you should put a record on and make sure you adjusted that screw under the arm enough. I had to do mine a couple of times. Hope this is helpful! Here's a video I found that better explains how to get the belt back on. http://www.youtube.com/watch?v=QaW84Z6GMVs
Posted on Dec 29, 2010
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
I have a Crosley CR66 turntable. I have a problem, whenever I play any record, the arm stops it's self too soon. Sometimes I don't even get to the last song before I get the "Click" noise...
The shut off mechanism underneath is activating prematurely. Locate it and adjust it for turn off further into the record (or closer to the spindle).
Sep 16, 2017 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Jul 24, 2010 | Crosley CR248 Turntable
Jan 12, 2010 | Crosley Audio Players & Recorders
Everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Sep 28, 2009 | Crosley 0187SST Turntable
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
Apr 01, 2009 | Crosley Audio Players & Recorders
Crosley CR249TA Turntable Logo
246 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
