Question about Logitech R-20 Computer Speakers
I bought Logitech R20 speakers in the UK - 240V and wish to use in the US -110V. Will the speakers work if conected to the lower voltage. Will the speakers be damaged if connected to 110V supply
4 Suggested Answers
SOURCE: Blown Subwoofer
did you manage to fix this problem ... i am afraid i might have made the same mistake. But I used a 220V-110V adapter that I have been using for the notebook. I dont understand why that doesnt work in the case of the speaker. Is there any way I can make it work again?
Posted on Jul 14, 2007
jackboy
  • 2985 Answers
SOURCE: blown speakers
No fix- buy new ones
Posted on Aug 14, 2007
SOURCE: what is the specific power transformer (internal)
No switch.
There is a transformer inside the bass box which should be able to be changed to a 110v, but its a bit of a pig to get into. There is a lot of glue securing the wires to the shell if you go via the panel, and it sounds like the speaker entry means probable destruction of the grill to get to the speaker mounting screws (4x). Yep, a step up transformer would be the least painful.
Posted on Jul 20, 2010
Tip
Dynaudio BM - Power from 110V to 240V or 240V to 110V
Hi Guys,<br /><br />This is what I have learnt the hardway so wanted to share it with everyone who wants to get his Dynaudio Speakers converted from 240V to 110V or 110V to 240V.<br /><br />I actually requested many forums including Dynaudio Support as I bought mine from US and they were 110V, I wanted to use it in my Country which has 240V standard, What these guys suggested me was to order the whole AMP Modules for the speakers if I want to have them work in my country. In other words it was a solution of $350 per module totals to $700.<br /><br />Shame on them as I opened the speakers myself and found a small jumper wire hooked up on the connections marked 110V and there were other connectors marked with 220V and 240V.<br />All I did was just took out the jumper from 110 and inserted it in 240V connectors!!<br />Thats about it!<br />So guys forget these mean techiz at Dynaudio and use my experiene to solve your problem :-)<br /><br />Cheers<br />Satch<br /><a href="mailto:satchriani2@hotmail.com">satchriani2@hotmail.com</a>
on Apr 04, 2011 | Dynaudio Acoustics BM6A MK II Active...
I have a cannon i9900 bought in US can I use it in Uk, do I need a adaptor
Check the mains input voltage on the printer. If it is 110v then you need a step down transformer 240v to 110v.
Apr 03, 2013 | Canon i9900 InkJet Photo Printer
Logitech z515 power US is 110V - israel is 220V - is US to EU plug adapter sufficient to use in Israel ?
No you cannot as 220v will damage the 110v the Logitech. You need a stepdown transformer to reduce the voltage from 220v to 110v. and then you can safely plug the Logitech into this stepdown transformer.
Jan 30, 2012 | Logitech Z515
Hp compaq dc7100 cmt can't start. 9 beeps and led red
9 beeps means that the input voltage to the PC's power supply is incorrect, have you changed the switch at the back of the PC from 110 to 240v or vice versa. If the PC was not bought in the UK then it may be set to 110v in which case the voltage selector at the back of the PC needs to be changed to 240v. If there is no voltage selector would recommend changing the power supply.
If by changing the selector to the correct voltage it still beeps 9 times you are looking at a new power supply unit which you can buy from HP at a high cost or buy a used one from:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160617535239
Hope this helps!!!
Jul 19, 2011 | HP Compaq dc7100 PC Desktop
Change voltage from 120v to 240v sony bravia 37L4000
I think that Sony Bravia are sold with dual voltage, 110V and 220V. All 220V devices work also on British 240V network.
If an electronic device is not compatible with the 240V/220V network, then the PSU must be replaced.
In your case the unit should be dual voltage, compatible with 220/240V networks. Just ensure checking the user manual, or the tag at the back of TV.
All you need in that case is an adapter that can be purchased at any local electrical shop (eg. Curry's if you are in UK).
Regards.
Jul 26, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Blown Subwoofer
Hi , you will have to open the box and check for any fuses along the power input line, replace them if any and try it out but i strongly believe what happened there is that you fried the power supply in your subwoofer , there is no easy fix to this , you will need to replace the transformer and possibly check to see if the rectification circuit is damaged too, and the amplifier too. Good luck
Mar 21, 2007 | Logitech X-230 Computer Speakers
Adaptor not working?
You need a transformer-type adapter that takes an input of 220-240V and steps it down to 120V output. If you bought the unit in the USA, you may have a problem if it is NTSC-only and doesn't have a NTSC-PAL switch to select the correct video format for India.
Dec 21, 2017 | Durabrand DUR7 Portable DVD Player
Logitech R-20 Computer Speakers Logo
19 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
