Studiomaster manual club2000 142 - Audio Players & Recorders
How do i use studiomaster ph1000x10 phantom power switch
Either turn it on or off, there are no other positions. If you do not have condenser microphones or anything else that uses phantom powr just turn it off.
May 06, 2014 | Audio Players & Recorders
Studiomaster horizon 1508 user manual
Try Googling (Studiomaster)(1508)(manual) without parens.
Oct 20, 2012 | Audio Players & Recorders
Hi, I need a schematic for a Studiomaster Powerhouse 300
For your requirement of the schematic for your model is not available now. But this schematic will help you. Visit http://www.studiomasterarchive.com/6-2-1sc.pdf and download the PDF. It will help you.
Jun 15, 2011 | Audio Players & Recorders
I have a studiomaster powerhouse vision 8 and when i turn it on the displays says ''incorrect pin'', i have never had to enter a ''pin'' and wouldn't know how to, it has worked perfectly for absolutely...
I have just had exactly the same problem with my up-to-now totally reliable studiomaster powerhouse vision 8. It finally let us down at a gig after 15 years faithful service.
Does anyone know how to fix it?
Feb 06, 2010 | Audio Players & Recorders
Hello, I need a Schematic for a Studiomaster 900E amp! Your help is greatly appreciated! ampguitdoc@sbcglobal.net
Apparently someone on this forum has them:http://www.diyaudio.com/forums/solid-state/140776-studiomaster-900e-schematic-needed.html You might have to join to post. You might also have some luck with this site:http://www.icxinyi.com/EN/
Jan 26, 2010 | Music
Studiomaster mosfet 1000
There is no danger from electromagnetic waves. There is certainly less than a 1970s Television. The manual didn't tell you very much unless you want to repair it. If you know about big amps, you know all you need. you won't be running bridge mode. The input can be shakey since its not really balanced line. Sometimes pin 2 is "signal" sometimes its pin 3.
Sep 07, 2009 | Audio Players & Recorders
Hi. I need a user manual for my Studiomaster
Hiya Pete, Unfortunately ever since they "restructured" anything prior for service is a huge issue with them and especially manuals. It is difficult to even get on the pay sites. You try request it at www.safemanuals.com but i doubt it. If it's something specific that you are needing, i might be able to help?
Jul 11, 2009 | Audio Players & Recorders
I need help unlocking a studiomaster p7
Hiya, cant promise but try this
First press "ps" then code "2111" then Func & PS together then 1111
Best of luck
Jun 20, 2009 | Audio Players & Recorders
46 people viewed this question
 Grubhead
Grubhead
