Question about Goldstar GVR-DD1 VHS VCR
Error Message on display
When I insert an 8mm tape, the display says "Alarm".  I cannot play, FF or Rewind a tape.
    Scholar:
  • 35 Answers
The alarm message usually means that the tape didn't load properly.  Instead of trying to play the tape and destroy it, the unit will just stop.  A common problem is that the tape heads don't spin.  Without a cushion of air between the heads and the tape, the tape will get ruined.  Sorry to be the bearer of bad news, but this is a repair that needs to be done by a tech.  The positions of the tape and heads are very touchy and have to be perfect.  I would try to find a repair center that can give you a good estimate and then determine for yourself if repairing the unit is cost effective.
Hope this helps :)
Posted on Oct 28, 2007
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
I have taken a rarely used Sony EVS2000 out of the closet to transfer some 8MM tapes but after loading the first tape I can't get any motor functions to work. No play, FF, Rewind or eject will function....
sounds like the mechanic is stucked. this happens because due time the used grease is loosing its viscosity. cleaning mechanic and regreasing will help. btw change of old rubber parts are recommended also.
Feb 27, 2011 | Sony EV-S2000 Hi8 VCR
When 8mm cassette is installed the word alarm appears on the screen. no functions will work, play, ff, rewind etc. it will eject
Assuming this VCR is compatible with 8mm video then there is an internal fault that will require a technician to diagnose.
Al
Feb 07, 2011 | Televison & Video
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | Televison & Video
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Televison & Video Logo
239 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
