Question about Euro-Pro Sewing Machines
Set screw size
Serger #100-547H need needle set screw. Been unable to locate any
bibleman01
  • 334 Answers
SOURCE: I lost the needle screw for Babylock EA 605 Serger
Almost all needle screws are the same size. Just check your yellow pages for sewing machine repair shops near by.Most of them would have it
Greg
Posted on Dec 05, 2008
Michaelle
  • 65 Answers
SOURCE: Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
  • 152 Answers
SOURCE: The needle in the C slot of my Husquavarna 936 won't stay in
Make sure you have backed out the screw almost all the way, grab the needle with a pair of needle nose pliers and push the needle up with "gentle" force to make sure it's up all the way. When you tighten the screw without a needle in the hole (when 3 thread sewing) the screw makes an indentation inside the needle hole. That indentation stops the needle from reaching it's upper most position. By "gently" forcing the needle up in the holder all the way, you correct the opening for the needle by breaking out that tiny imperfection. Your needle screw then can hold the needle correctly.
Posted on Oct 10, 2009
  • 1788 Answers
SOURCE: I have an older model
Call Singer at 1-800-4singer and see if they can sell you that part. I am sure that they can because they do not change the parts that much on the machines. Good luck
Posted on Jan 18, 2011
Tally Girl
  • 1125 Answers
SOURCE: Need a set screw for
you could try a generic one from this website and see if it fits?
http://sewing-machine-parts-store.com/list.asp?subcat=Screws
Posted on Mar 30, 2011
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
I changed broken needle but accidently both of them came out now the left needle does not stay in
Assuming this is a serger? Is there only one needle set-screw on the machine or one set-screw for each needle? If there are two set-screws, then you may have accidentally lost the set-screw for the other needle. If there is only one set-screw, both needles will need to be installed at the same time, hold them all the way up and simultaneously tighten the set-screw.
How To Change The Needle on the Brother Serger 1034d 4 Thread 2 Needle... (this machine has only one set-screw for both needles)
Some other machines, ie Bernina, have a set-screw for each needle.
Dec 09, 2016 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
7. Is the thread feeding off the cone/spool freely?
Aug 21, 2013 | Singer 14SH654
I broke my needle on my frontier simplicity serger and i need to know how to change it
usually a little screw driver that you use on glasses is ok to use or
a small screw driver that size. that's what I use on my serger.
Nov 01, 2012 | Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes. http://sewingmachine221sale.bizland.com/store/page78.html
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
I lost the needle screw for Babylock EA 605 Serger where can I get one?
Greg
Dec 04, 2008 | Tacsew 20U43 Sewing Machine
Sewing Machines Logo
16 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
