Question about Hamilton Beach Water Cooler with Storage Cabinet
Have primo 900146 hot water works, cold water not, switch is on turned tstat screw, no frost on coil, compressor running
Why will my frig not do it's defrost cycle? Could it be the temp Fuse - where is it?
First off try taking a vacuum cleaner and cleaning off your coils of any dust, dirt or hair that is blocking good air flow to make sure your refrigerant is as cool as possible before it hits the compressor.
If you have frost on your evaporator coils that means the coils probably are covered in an ice layer which stops the coils from absorbing heat from your refrigerator because believe it or not, 32 F ice is not near as cold as evaporator tubes with refrigerant running thru them at about -20F or lower.
So make sure there is a nice unobstructed air flow to condensing coils and fan so the heat from refrigerator compressor can be carried away properly.
After everything is really clean, turn refrigerator completely off for the night to make sure any ice formed on the coils is melted away. Any ice on the coils will screw up the thermostats and then the refrigerator will turn on the compressor to run even when it shouldn't
So do a complete manual defrost before going back on
Nov 20, 2015 | Frost Refrigerators
I have a whirlpool full size refrigerator el87trrrv02. I noticed it was not cold but blowing air. We pulled it out and began troubleshooting. There was what seemed like too much water in the drain pan, no...
1st fix the timer problem, next if the temp is erratic by-pass the thermostat for 3 ~ 6 hrs and see if the unit continues to drop in temp. Never run the REF on an extension cord. If the evap only gets cold near the cap line could be a system leak.
Oct 30, 2013 | Refrigerators
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Kbra22kmss fan never stops freezer has frost
adjust the thermal level switch to normal position
Aug 01, 2012 | Refrigerators
Compressor runs bypassed thermostat with wire that turns on and off compressor,but freezer cabinet is not cold 65 degrees evaporator fan does not turn on,condensor fan on,sttill no cold
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Mar 30, 2011 | True 23 cu. ft. / 651 liter Commercial...
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
Hot water gong cold
Hi .. sounds like the upper thermostat control on yyour water heater needs to be replaced. This could be a DIY project. turn power off and swap the wires from the old tstat to the new tstat. Be sure to have the tstat mounted so the back is in full contact with the metal mater tank.
Apr 27, 2010 | RELIANCE ELECTRIC WATER HEATER
Compressor running very hot but almost no cooling. Fan running
make sure the coils are clean both evaporator and condenser,then if there is a capacitor in the motor circuitry,check this,finally if the coils frost,then clear up and frost and clear up time and again,this is a sign of low refrigerant R134a,and this also will make the compressor run hot
Apr 09, 2010 | Haier 45-Pint Dehumidifier
Frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Nov 26, 2007 | Maytag MSD2650H Side by Side Refrigerator
Hamilton Beach Water Cooler with Storage Cabinet Logo
209 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
billconfused
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
