Question about Dometic RGE400 Top Freezer Refrigerator
Dometic refrigerator freezer freezer has stopped working
Refrigerator is n freezer is not freezing
22yooper
  • 828 Answers
SOURCE: REfrig and freezer not cooling
These unit must be level to function. Never side to side tilt but it is permissible to have it tilted a little toward the back. This would be the first step.
Posted on Jul 31, 2008
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 68 Answers
SOURCE: Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Posted on Mar 19, 2009
projdoc
  • 2236 Answers
SOURCE: my dometic refrigerator rm2852 is freezing up.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
SOURCE: Food freezes in the refrigerator part of my
Food freezes in the ref. Freezes in the door, the top shelf and the bottom shelf. Salad dressing even freezes! What can I do?? Please help! feefa_7@hotmail.com
Posted on Nov 02, 2010
Refrigerator freezes everything in the refrigerator
Usually, there is a control knob/dial somewhere in the fridge. Did you try turning it to less power?
Nov 18, 2013 | Dometic RM2652 Refrigerator
I have a Crystal Cold propane refrigerator and
You more then likely need a new thermostat. b0560f71-786e-45e7-a413-9112b90c0a0f.jpg
Sep 14, 2013 | Dometic RM2452 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Works good on electric. The freezer freezes on
make sure your gas level is right. low gas levels can cause your problem
Aug 07, 2009 | Dometic RM2652 Refrigerator
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
27 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
