Question about Hannspree 10.1" Android Tablet Grey Tablet Android 4.1, LCD Touchscreen, 1280x800
G sensor stopped working - Hannspree 10.1" Android Tablet Grey Tablet Android 4.1, LCD Touchscreen, 1280x800
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
My tablet was working fine when I brought it from Amazon now it won't coonect to my wifi it says establish reliable connection to the server, I tried other WiFi connections same message
Go to your setup setting and check your wifi setup might have change because it not storing the setting might have a problem with the tablet would replace if under warranty
Apr 20, 2015 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Url has stopped working
I know when my zeki stopped working I saw that there was a place on the side to reset you push it in with a paperclip just for a few seconds and this reset the zeki, other than taking it in a repair shop and having the whole thing set back to when you 1st purchased it. I hope this helps
Mary
Mar 09, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
Visual Land Prestige 10 G-Sensor will not work or calibrate. HELP
having the same issue with my tablet what do i do
Jul 16, 2013 | Tablets & eReaders
Samsung q1 black screen
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Mar 12, 2008 | Samsung Q1 Tablet PC
Hannspree 10.1" Android Tablet Grey Tablet Android 4.1, LCD Touchscreen, 1280x800 Logo
87 people viewed this question
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
ka4iup
ka4iup
William Alequin
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
