Question about Toto Home
Replacing aerator in toto bidet
Water pressure in bidet is low
  • 74 Answers
SOURCE: No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Posted on Apr 25, 2009
  • 115 Answers
SOURCE: Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
Posted on Jul 26, 2009
SOURCE: SB-620 Magic Clean Bidet
CALL 800-681-0753 FOR PARTS
WWW.BIDET1.COM
Posted on Feb 26, 2010
  • 83 Answers
SOURCE: Hello, I replaced the seats
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
Posted on Nov 22, 2010
  • 3 Answers
SOURCE: I recently removed and reinstalled my kitchen
take the unit apart, starting with the handles and check for small rocks or derbis blocking flow.
Posted on Mar 24, 2011
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
Water is leaking slowing after filling up the tank and water supply is shut off. where is the leak?
In this toilet there is a flapper valve that blocks the hole for the water to transfer from the tank to thebowl. If you fill the tank and water is leaking into the bowl put your hand in the tank and apply alittle pressure to the flapper, the leak should stop. You can buy replacement parts for this toilet at Home depot or Lowes they carry universal lits that are perfect for this issue.
Jun 14, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
Jan 28, 2011 | Toto Drake ADA Compliant Toilet with...
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
Increasing water in bowl
You really can't because of the design. Any water above the level now will drain off. Sorry
Nov 04, 2009 | Toto Toilet Onepiece Neorest 600 ...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
Home Logo
66 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
