Question about Sky I Blade Mini IR Helicopter W/ Remote Control
My helicommand rc heli won't do any thing when I turn it on, evn when charged full, the lights won't even blink!
The light won't even blink.
RC helicopter no longer responds to controller
1st,
extend the antenna out. (unwrap from skids ) and wrap it to the tail fin and back.
Also check the connection to the RX pc board. May need to be soldered better.
These are 23mhz,72mhz radios and Binding (which is a 2.4ghz digital system) is not going to happen here.
What to look for is the led on the heli rx. Turn tx on first, then heli. Look at led. It will blink at first then go solid when it syncs to the TX signal.
The heli should have the channel sticker on it (look at rx also) this needs to match the tx (some tx have a channel selector 1,2,3- a,b,c).
Jan 12, 2014 | Toys
Tip
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
on Sep 26, 2011 | Silverlit Toys Red Air Hogs R/C Havoc Heli...
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
How to charge rc ignite helicopter
There is a male jack in the right side bottom of the remote. It looks like the end of a lap top charger only smaller. on the bottom of the heli there is a hole where it fits into. make sure it is in far enough, Not all the way! the heli must be off and the remote must be on. when it is charging the on-off light will blink. when it stops blinking it is charged. if it doesn't blink when you plug it into the heli try pushing the jack in a little farther. mine when in and stoped and i had to push just a little harder to seat it. Good Luck:)
Mar 04, 2012 | Toys
Just bought an S107G. I have brand new batteries in the controller, and the heli is fully charged. The light on this controller when turned on is solid red at all times (should be green right?) The...
Do the lights on the heli come on?
Normal start-up would be:
Turn helicopter on. Flashing light in nose should come on, as well as another blinking light (sometimes towards the rear, sometimes in the "cockpit" area) the helicopter MUST then be placed on a level stable surface until the 'other' light stops blinking, usually a couple/few seconds. This is the gyroscopes synching up and determining the "level" head orientation they will be maintaining. Then power the controller on. Making sure you're not covering the front of the controller with your hands, (the IR signals come out the front like a TV remote) push the throttle control (left joystick) up until the blades move. This what the horribly translated instructions mean by setting the helicopter and controller together.
Don't charge with the controller. It kills your controller's batteries, (which will last nearly forever if you don't use them as your heli's charger) and seems to make the birds act weird. Use the USB charger and a fully powered USB port (back of your desktop, not the front) and go by the light on the charger not an arbitrary time. Plug in charger NOT connected to heli. Look at the light. That is what the light will look like when unit is fully charged. Make sure heli is off. Plug into charger. Charge until light is fully on. If you unplug heli and the light gets brighter, it's not charged fully. A weak USB port (on a laptop or the front side data port on most desktops) may take several hours to achieve full charge. Always cool 10 mins after charging AND 10 mins after flying. Never drain fully, it will kill the Li/Po battery. Land and power off as soon as you can't maintain altitude.
If it is really charged, and you turn it on and nothing happens... no lights nothing. Then it's defective/toast. Return for refund.
These SYMA helis are awesome, and HANDS DOWN the best on the market... but they can be picky/tricky on how they are treated.
Please let me know if this helps.
PvT
Jul 27, 2011 | SYMA Toys industrial New Syma S107 Mini...
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
My syma s107g gives a flash light in the circuit board and does not work
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli
wait for blinking green led to stop blinking-turns steady.....rev up
with a quick full throttle and back to idle--happy flying
Feb 20, 2011 | SYMA Toys industrial New Syma S107 Radio...
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
Hey my heli will not take off or not turn on
i had the same problem, the first thing you want to do is make sure everything is off and you have to charge it for around 3 hours for the first time so make sure you let it charge until the red light stops blinking then make sure all the blades are correctly alligned then make sure the controller can turn on if thats all good then make sure you always turn the controller on first and then the heli and i figured out with the reflex that if you barely push up the throttle it wont even start to spin so push it up all the way or try the directional stick and see if it works
Dec 29, 2008 | Spinmaster Air Hogs RC Reflex Micro...
Sky I Blade Mini IR Helicopter W/ Remote Control Logo
64 people viewed this question
Top Sky Toys Experts
NOEL
NOEL
matt
matt
Are you a Sky Toy Expert? Answer questions, earn points and help others
