Question about AOC Televison & Video
Connecting sony blu ray dvd player to AOC tv
I get "No Signal" on my AOC flat panel tv and I have audio/video out and audio/video in hooked up correctly. Is there anything else I need to do?
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 83 Answers
Try setting your TV Input to AV. Are you sure that you have the audio and video cables connected properly? Video out to video in and audio out to audio in? It can be easy to get them reversed.
Posted on Jun 25, 2016
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
Posted on Dec 29, 2009
  • 380 Answers
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Posted on Dec 30, 2009
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
SOURCE: Westinghouse LCD TV 32'' not working with Blu Ray DVD player
I have the same issue with this TV and an Xbox. it can't keep a HDCP connection and my research shows that it either can't support HDCP or I have a cable that isn't able to support the speed (It pretty cheap) or signal, or it's a bad cable. I'm going to swap it out to see. But Blue Rays use HDCP and you may be having the same issue.
Posted on Jul 29, 2010
Connecting a Sony dvd player to an AOC flat screen TV
Set your TV Input to AV. Are you sure that you have the audio and video cables connected properly? Video out to video in and audio out to audio in? It can be easy to get them reversed.
Feb 09, 2014 | AOC Televison & Video
Trying to connect my laptop to the tv
Some details are needed - what type of connection from laptop? VGA 15pin or composite video for example. What kind of TV - I assume some modern flat panel. Did you use the function key on the laptop to send the video signal to the external port. Audio gets supplied to the audio port all the time so that is why you have audio, but the video signal is normally directed to the LCD screen. The function key (F5 or F7 typically) changes this and blanks the LCD and send the signal to the external ports. Press again and you get both LCD and external ports together. This is absolutely the most common problem with people hooking a laptop up to an AV system or device.
Dec 31, 2013 | Televison & Video
AOC L24H898 has audio, no video
This sounds like a power supply problem that causes the high voltage power supply to shut down when it warms up. A repair shop may be able to fix this.
Apr 21, 2012 | AOC L24H898 24 in. LCD TV
I cant get any color when i hook up my x box orginal.. tv color works fine.. i have tried plugging the white into the blue and nothing happens.. What needs to be done to be able to have color when im on...
White is your audio signal, not video. If you are using a composite hook up, yellow is your video and needs to go in the yellow slot. White and red is your left and right audio. If you are using a component hook up, then you will need to use red, green and blue for video and white and red for audio.
Apr 11, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Hello I just bought AOC L22W898 22" Class LCD HDTV and i tried to connect it to sony play saton with HDMI but it is can's be connect it says no signal. Other inputs working perfectly. I tried to...
It might be that the PS3 is sending an incompatible signal to the TV. I'd connect the PS3 using normal RCA jacks, and make sure that the video mode in the PS3 menu is set to auto.
Mar 16, 2011 | AOC L22W898 22 in. LCD TV
I have an LN37A330JID and there is no video, just audio. A blue square centre screen says "weak or no signal". I tried new video cables but no change. It was going through a stereo receiver...
This probems could be the cable or satalitle receiver boxes itself.Might be the tv Tuner signal board itself is the causes,because it have some kind of shorts inside the tv Tuner signal board circuitries itself.Tries to hook up with a another tv with that incomming broadcasting signal cable.If u have no trouble,than it is the tv Tuner signal board.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 03, 2010 | Samsung LN37A330J LCD TV
Just tried to hook my aoc 22" to high definition
I beleive you have to enable audio in the HDMI SETUP so it will send the digital audio through HDMI ports, check the cable box and the TV HDMI sound setup.
Nov 19, 2010 | AOC L22W861 22 in. LCD HDTV
Buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Sep 20, 2009 | AOC L24H898 24 in. LCD TV
I can't seem to hook up my Insignia T.V. and my dvd player up
The way to hook up the dvd player to the television to to put a cable into the output signal section of the dvd player( Ther may be many different ways to hook-up the signal s-video and component video, regular video. You must pick one of these output signal sources to put into the input section of your television by matching them up i.e s-video out to s-video input compnent video output to component video input, regular video out to regular video input. For each of these video hook-ups there will also be a set of two sound cables. Look on the back of your television for the signal input section and hook up the video cables and the sound cables to your selected input. You should do this with both units turned off in order not to damage the circuits by shorting them on cable insertions ofr causing heavy feedback in the circuits. One this connection is complete. Trun on the television first and select the TV's signal source . By pressing the input button and using the up and down arrows to find the correct selection. By matching up all three sources you now should have the correct signal path. Turn your DVD and test the controls. try using the volume control and use you dvd to to play,ff, or stop the dvd.If all this works then you have done the set up correctly and can now enjoy your dvd's on the television Hope this helps you with your problem..
Mar 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
Televison & Video Logo
16 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Jayesh Panchal
Jayesh Panchal
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
