Question about Sharp AR-651 Copier
VOIDS Copies have voids which get worse with multiple copies
    Problem Solver:
  • 9 Answers
Do you have a AR-LC4 attached to the machine, if you do make sure that it is attached securely and level.
If that doesn't work, check your developer unit looking at the drive gear in the back of the unit.  Turn the gear and make sure that it turns the mixing paddles without slippage.  If it slips, replace the gear.
If it turns everything okay then check the mixing paddles it self to make sure that none of them are broken and not getting toner to the developer, if they are broken replace them or replace the whole developer unit and developer.
Posted on Oct 27, 2007
  • Kelvin Jones Oct 27, 2007
    Oh yeah, an AR-LC4 is a Large Capacity Feeder that attaches to the right side of the machine.
What's your question?please how do I copy multiple copies with canoniR2000? mine copy's one n display incorrect paper size
Copying What You've Already Drawn ' SketchUp ...
https://help.sketchup.com/en/article/3000092
SketchUpWhen you copy and paste with the Move tool, you can make a single copy or createmultiple copies and tell SketchUp how to space them - if you know the ...
For Sale Canon IR2000 digital copier ' Facebook
https://www.facebook.com/media/set/?set=a.144875105642811...3
For Sale - Canon IR2000 digital copier Copy Speed 20 CPM First Copy ... Time 30 Sec Zoom 50-200% Duplexing Not supported Multiple Copies 1-99 Copier ...
Can I make multiple copies of the same DVD? - DVD-Cloner
www.dvd-cloner.com > DVD-Cloner Knowledge Base
Of course you can. Please use the option: "Number of copies" in the "Burn I/O" tab of the "Advanced setup" window. You can make multiple copies of the same ...
Canon Ir2000/2010/251/271Digital Copier - Buy and Sell Plus
www.buyandsellplus.com/.../Canon-Ir20002010251271Digital-Copier
Aug 28, 2012 - First Copy : Approx. 8.2 seconds. Max Copy / Orig. size : A3. Copying Resolution : 1200 x 600dpi. Multiple Copies : 1-99. Magnification Zoom ...
[PDF]iR2000/iR1600 Reference Guide - Canon
Dec 26, 2015 | Office Equipment & Supplies
Free solution of black bars on paper while printing on xerox dc 12 printer
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
My minolta ep 4000 copier prints with thick black streaks imprinted on page. what's wrong? is it the corona, the drum, or something else?
Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Jul 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
Voids when copying
voids or arears of no print could be two things. moisture in paper. try fresh paper out a sealed packet. two- the developer is at fault on needs to be topped up or replaced
May 05, 2010 | Office Equipment & Supplies
Voids on copy. What do I clean and how do I do it?
voids on copies can be two things, 1st it can be caused by moisture in the paper, try fresh paper out a sealed packet. two- the developer is at fault and may need to be topped up or replaced
Apr 28, 2010 | Office Equipment & Supplies
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
COPY QUALITY
Voids are most often caused by lack of sufficient developer, which needs to be changed by a technician. developer has metal beads in it to draw the toner and make a full (dense) copy or print. these beads wear out or "dump" which initially cause gritty prints, then washed out prints. hope this helps.
Jul 09, 2009 | Toshiba e-Studio 45 Black and White Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
