Question about Flotec 11/32 HP Sewage Ejector System FP400C
My flotec sewage pump hard stop vibrating the concrete floor with loud thud noise with a thud loud sound.the wall straps are firmly secured. JACK. wall straps are firmly secured.
2 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: how to clean a sink flotec pump
It sounds like the float is stuck. Try pulling the wires coming out of the tank(shake them a little) and see if that will free the float and shut the pump off
Kurt
Posted on Apr 08, 2009
2000 Buick Century 69k mi. automatic trans. hard thud changing from 1st to 2nd gear, whining noise between gears
No idea without a drive so please ask a local mechanic to have a look for you
Dec 19, 2013 | Cars & Trucks
I recently got an Iron Cleer system; 3 tanks total. It is installed in a downstairs little utility room, with a door, along with the water tank/well pump. My problem is the compressor on top of the...
If there is available space, mounting it on a 4" inch, wooden riser (sturdy enough to handle the weight) with a rubber mat on top of the riser, may help to dampen the noise. As, it won't be making any contact with the concrete floor and vibrating and reverberating throughout the house. I don't see bolting the compressor to floor as a good solution. As, some vibration and reverberation would still be occurring.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Heating & Cooling
My flotec sump pump began making a loud suctioning noise when it stops. Now this continues as if the arm is not lifting properly. At times the pump doesn't stop , but continues to make this noise as it...
It sounds like your float is hanging up. Yes, it does sound like your pit is too small. If it is smaller than 18" in diameter, it is too small. A small pit is bad for the pump too because if it is raining hard, your pit will fill very quickly. Now when the pump runs, it will empty very quickly. On-off-on-off-on-off is very bad for the pump.This is what is known as short-cycling, and it will burn up your pump in no time because of the constant on/off cycles.
Jun 16, 2017 | Flotec Plumbing
I have constructed a hall for the purpose of meetings. But now there is too much of echoing within the hall. even without loud speakers. With loud speakers, it gets worse. How solve this problem of echoing
Excessive room echo is caused primarily by two things - hard surfaces and high ceilings. The worst materials are glass, marble and concrete block. Next to this is drywall. The more hard surfaces you have, the worse the echo will be. For example an entirely drywall room is much worse than one with drywall walls and an acoustic tile ceiling. The sound simply bounces from the back wall, to the front, to the ceiling, to the floor, back to the walls, floor, ceiling and so on. The solution of course is to reduce the amount of hard surface area.You need to coat the wall with some sort of acoustical wall treatment. Carpet on the walls will work or you can purchase materials for that purpose. How much to install and how much area to cover will require experimentation. There are many choices and this is just one.
http://www.acousticalsolutions.com/
An online search will provide many options. Search will the term "Acoustical Wall Treatment"
Oct 08, 2010 | Hammering
When using hot water, the Rheem revs up like a motor cycle
I would check and see if the ventpipe that is coming off of the top of the motor is strapped to any duct work in the basement or touching and floor joyces. Even if the venting is touching the duct work a bit, it will amplify the vibration through out the home.
The only other issue it could be would be that the fan blades are bent and rubbing up against the inside of the motor causing the noise and extraem vibration
Jul 29, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I am getting a lot of vibration from my pump
there is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Jun 20, 2009 | Little Giant 2-MDQX-SC Inline Pump
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Won't drain or spin out
Dec 12, 2008 | Danby DWM99W Top Load Washer
Maytag front load washing machine
I have the same problem and its making me crazy.
Feb 04, 2008 | Maytag Neptune MAH9700 Front Load Washer
Flotec 11/32 HP Sewage Ejector System FP400C Logo
19 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
