Question about Sport & Outdoor - Others
Yamaha waverunner forum
2004 waverunner i ran it one day with out any problem. then a week later it wouldnt roll over. pulled plugs sill nothing not even a click from starter. gauge reads 12.7 volts. took intake grate off and rolled it over with pipe wrench, was kind of stiff, not sure if thats normal. its in storage now and hadnt thought to see if the security mode came on, can this happen by itself?
  • 44 Answers
SOURCE: Car Wont Start
It could possibly be a battery with no or very low amps. I would get it checked by a dealer or many auto parts stores have battery testers.
Posted on May 20, 2008
SOURCE: We have a Kenwood KDW8ST2A
You can find a manual here
Posted on Sep 16, 2008
SOURCE: Waverunner will not start
Check the fuses under the front in a round cover, 1 fuse is for the starter,but the cover must be on after checking the fuses.
Posted on Jul 13, 2009
  • 24 Answers
SOURCE: waverunner sat for 4 months. thought battery was
Try jumping the waverunner using a set of jumper cables and your vehicle, this will rule out if the battery is bad. If you still have the same issue, check the connections. The connection at the starter or another place may have corroded a bit. Yet another option is to remove your spark plugs to make sure that your motor has not hydraulically locked. Once you have removed the plugs try and turn over the engine. You may need to ground out your plug wires if you have an electronic ignition to protect it. I hope this helps.
Posted on Jul 14, 2009
SOURCE: 1994 Yamaha Waverunner 3 will idle but wont take throttle
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
Posted on Aug 31, 2009
Help with 92 waverunner 650 no spark issue
Hi, Banjomaniac and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Thread Waverunner No Spark
1991 waverunner III 650 turns over no spark won start Want to fix for the...
Jet ski 91 Yamaha wave runner 650 with no spark need some
http://www.yamaha-motor.com/assets/service/manuals/1998/LIT-18626-03-05_371.pdf
Aug 01, 2016 | Motorcycles
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-344777.html
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
More results from www.snowest.com
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/...snowmobiles/5470-pull-start-not-workin...
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from www.snowmobileforum.com
Jan 04, 2016 | Garden
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
Sep 18, 2013 | Yamaha 2004 WaveRunner FX Cruiser
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
2004 R1 WANT ROLL IN GEAR
Hi, Jimmie for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6messagenet.com/forums/r6-maintenance-technical/76925-1st-gear-clutch-bike-wont-roll.html
Dirt Rider Magazine
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 22, 2012 | 2004 Yamaha YZF-R1
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Strong vibration 2004 yamaha xlt waverunner
Something was stuck to the intake obstructing flow.
When you shut it off it drifted away.
It is a good practive when in weedy or heavy debree areas to get clear shut the motor off count to 30 then restart and gradualy excelerate to make sure it is clear. used this method for ten years now and seems to work well for me.
Jul 21, 2009 | Water Sport
1997 Yamaha Waverunner not starting and no electronics
mine did the samething as sooon as i got it on the trailor i tried to start it and the starter was froze up (worked fine in the water) so i replaced the starter and tried it and nothing happend. i went into the black box and figured out my starter relay burned up trying to get power to the starter. works fine now after changing relay and starter
Nov 23, 2008 | Boating
Sport & Outdoor - Others Logo
12 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
