Question about Sungale DVD-2026 DVD Player
How do I format my sungale 2026 to play dvd's
I always get "disc error" or wrong disc message
snakehead
  • 1074 Answers
SOURCE: DVD player will not play
my brother the only way you can override that lock is that the microchip in the set has to be lift out of the set,by doing that the chip will reset itself then the chip can be resolder back contact a tech to do it for you.goodluck.
Posted on Mar 30, 2007
SOURCE: wrong disc message displayed on
I found these posts. I have only been able to get the fix to work once, though. :(
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Region code hack posted by jeff777, December 15 2004:
This works.
1) With remote control, power the DVD player on.
2) With remote control, open the DVD tray.
3) With remote control, select SETUP.
4) With remote control, press the VOLUME UP button, then the VOLUME DOWN button, then the VOLUME UP button again and finally the VOLUME DOWN button again.
5) You should now see a number 2 on your screen. If you do not, this hack will not work on your system or you have done something wrong. If you do see the number 2 on the screen, proceed to 6).
6) Use the LEFT and/or RIGHT arrow to select the number 255.
7) When you see the number 255, press the SELECT button.
8) Press the SETUP button again to end procedure.
Region code hack posted by RayH, May 18 2005:
Newer Sungale 2026 players are a bit easier to set up:
1. Open the tray
3. Press "8-8-8-8" Region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region. "255" all region.
5. Press "Setup" to exit.
Tested Region 1, 2, 3, 4, and 5 PAL and NTSC disks. They all work just fine on an older US NTSC TV. It's a little bigger than the Cyberhome, but works much better. There is no jerking at chapters with either factory or homemade discs. Plays VCDs just fine.
Sniff around the internet. This machine is availabe as of 5-18-05 for about $29 plus shipping ($11). Arrived in two days.
Other hack posted by Hurricane, January 23 2006:
If you do the Setup>8888 thing you get a region code 1-6 & 255.
Well if you press up and down on the directional pad you also get 3001 and 4001 these can be changed to 3000 and 4000, I know that one of them is a Macrovision on/off flag but I don't know what the other is.
Region code hack posted by Streetmedik, March 25 2006:
I have the Sungale DVD2026 I have tested this with DVDs from various regions. It works.
1. Power on
2. open the tray.
3. ON THE REMOTE press the VOLUME up, down, up, down.
4. ON THE REMOTE press SETUP
5. ON THE REMOTE press the up and down arrows to go between the macrovision/region codes.
6. ON THE REMOTE press the left and right arroes to change the values.
Macrovision
3001 on
3000 off
Regions
1,2,3,4,5,6 = individual regions
255 = all regions
7. ON THE REMOTE press setup again and you are set.
You can change these values again and again If you just want to play around.
Posted on Jul 26, 2008
SOURCE: sungale dvd player 2026
I have the same problem many times. I simply rotate the player 90 degrees on it's horizontal axis, so that the opening is facing toward the ground. Then, hold the door open and press the "Open" button. It's pretty ghetto but it always works for me.
Posted on Aug 08, 2008
  • 51 Answers
SOURCE: need remote
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12306100697510&smodel=DVD2026&brand_pn=SUNGALE_DVD2026
Posted on Dec 30, 2008
SOURCE: Sungale DVD 2026
i had the same problem. just through it out. its not worth it.
Posted on May 05, 2009
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Office Equipment & Supplies
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
On my Husqvarna Viking sewing & embroidery machine...when I put in a floppy disc I get the error message: General disc error. What is wrong?
It can't read your disc, it may be damaged or needs to be cleaned. It could also be the wrong disc for the machine. The machine can't recognize it.
Jan 24, 2014 | Husqvarna Sewing Machines
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
Disc error message
Sounds like dirty laser pick up. Try a cd cleaner run through it to clean dust etc off. They can be purchased from any electronic sellers.
Jan 11, 2010 | Zenith Televison & Video
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Wrong disc message on Polaroid TDM 1421C
Polaroid has always been known to have a bad dvd assembly. Easy to replace, 4 or 5 plugs, high failure part, hard to get and usually out of stock.
Feb 13, 2009 | Polaroid TDM-1421C TV
WRONG DISC ERROR MESSAGE.
Inside the machine the laser will sometimes adjust itself to a position just out of reach of the disc and you will get a "default message", so it doesn't necessarily mean you have the "wrong disc". This can be adjusted by yourself or take it in to be done. This is only, of course that you have covered the basics and cleaned the discs and inside machine. Just blow in it even, they do attract dust as dvd's are like a magnet to dust.
Aug 23, 2008 | Spectroniq PDV-70X
Error message wrong disc
wrong disc keeps appearing when dvds are put in to machine
Jul 10, 2008 | GE 13TVR72 13 in. Combo
Sungale DVD-2026 DVD Player Logo
62 people viewed this question
Top Sungale Televison & Video Experts
janman
Chris Baker
Chris Baker
Level 1 Expert
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
