Qcap2f cap does not turn off - Computers & Internet
For some reason the gas cap on my 83 280ZX won't come off. The cap is not locked, it just turns but can not be removed
in the cap there is a clicker to stop you over tightening the cap if this goes as it been turned around and blunt its cogs the cap will not come off, you need to get a blade of a large flat screwdriver and try and get it in the gap between the cap and tank top and twist and turn the cap at same time.
May 15, 2017 | Cars & Trucks
Caps lock key wont turn off by pressing caps lock light dell inspirion 15
Do caps turn on/off and only the light stays on? Have you tried using the onscreen keyboard to turn it off, assuming it never turns caps off?
Jun 30, 2014 | Dell Inspiron Computers & Internet
Can't remove cap to fill anti freezes
It should come off that way. Apply more downward pressure, hard, and turn till it stops and won't go any further. Then pull straight up There are tangs on the bottom of the metal top of cap that must be turned (towards loosening) before they allow the cap to be removed. Possibly, you haven;t turned it far enough.
Jul 06, 2012 | 2010 Dodge Journey
When I try to remove the cap to add oil in my 1997 silhouette van the cap turns a revolution or two then stop. The cap won't come off until I keep turning, and then the cap and filler neck come off as if...
You are correct, sound like the filler cap is to tight, it happins, grab the filler tube and cap and remove the old cap and replace with a new one, you might have to break the old one to get it off.
Mar 22, 2011 | Oldsmobile Silhouette Cars & Trucks
How do I get the radiator cap off
PLASTIC RADIATOR CAPS ON THE OVER FLOW JUGS YOU TURN COUNTERCLOCK WISE TO REMOVE. THE METAL RADIATOR CAPS ON OLDER VECHICLES. RADIATORS YOU PRESS DOWN OR CAP WHILE TURNING COUNTERCLOCKWISE TO REMOVE CAP.
Aug 30, 2010 | 1999 Oldsmobile Alero
Gas cap warning light is on. Gas cap is tight.
If the cap is tight then you need to replace the fuel cap. the light will go off when cap is replaced
Jul 13, 2010 | 2000 Dodge Caravan
Check engine light is on and where the milage goes it says gas cap
Your gas cap is loose and setting a code, may need to replace cap. When you tighten gas cap turn cap slowly it may seal better. You should feel it turn before it starts to click..
Feb 23, 2010 | 2006 Chrysler Pacifica
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Yamaha V-Star 1100 Gas Cap is Stuck
shoot wd40 into locking mech and press down hard on cap while turning key.....Tim
Jun 01, 2009 | 2003 Yamaha V Star 1100 Classic
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
