Question about Zenith XBR716
Dvd keep saying " NO DISC ".
TRIED CLEANING DISC.
2 Suggested Answers
SOURCE: It keeps ejecting the disc and saying disc error
Now what this joker isn't telling you is that the 'hack' below actually resets the player to factory defaults. It just worked for me perfectly.
Now you might have to go back into setup and readjust some of your settings. (i.e. freq response)
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
Posted on Apr 13, 2009
My Denon DVM-1800 says no disc what do I do?
I have had the same thing happen with my blu-ray. I have tried cleaning the disc; the lens, occasionally with success. flashing the bios. also known as update of the system [can be done online {if equipped} of mine also has a usb port {download the correct file to a USB drive and re-power DVD with the drive in place}]. if these things don't work try manufacturer tech support. I had mine replaced because it wpould NOT flash. good luck.
Apr 07, 2012 | Denon DVM-1800 DVD Player
When I put a dvd in it says "loading" for a good
Try cleaning the laser lens. Either opening the unit and cleaning with a cotton bud, or try a lens cleaning disk.
Oct 24, 2011 | Televison & Video
My Memorex won't play DVDs, it only shows "wrong disc."
No help i know, but my Liton is in the same condition. Except mine keeps saying Insert disc...
Have you tried using a cleaning disc in case the laser is dirty?
It didn't cure mine, but you never know...
Aug 15, 2009 | Memorex MVD2040 DVD Player
Toshiba D-VR4 DVD recorder/VCR player
you can get the cleaning disc at any electronic store or even at some other stores like drug stores and even at the dollar store , but if the laser lens is probably to dirty to even see that disc if your player will not even read a music disc, have you tried a music disc? can it read it ? if so the cleaning disc will work.
if not then taking the player apart and manually cleaning the lens will be required
Dec 29, 2008 | Toshiba D-VR4 DVD Recorder/VCR
DVD player error
Try cleaning the lens using a cotton swab and alcohol. Next try playing a CD. If the D plays but a DVD does not, the optics are weak and need to be replaced.
Keep us posted.
Dan
Apr 09, 2008 | Televison & Video
Ilo dvd recorder
This could be a fault with the spindle motor that spins the disc.
I think you might try inspecting the brushes on this motor for wear or misalignment.
Oct 18, 2007 | iLO DVDR05 DVD Recorder
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Zenith XBR716 Logo
81 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
