Question about Onkyo TX-DS595 Receiver
Optical connection only plays in PCM
Can't get the optical output to become digital--stays PCM and the digital light on the display will not turn red
2 Suggested Answers
SOURCE: PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Posted on Dec 10, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
How to plug my external speakers to my viera tv
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Oct 28, 2014 | Panasonic Smart Viera E50 Series Tc-l47e50...
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
Iriver ihp120
Back in the tools disk is an option for infa red input/output connection to your computer. Some how this option was activated, and it is looking for your wifi.
Jun 05, 2007 | iRiver H320 MP3 Player
Onkyo TX-DS595 Receiver Logo
15 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
