Worldstar MG-6000 Multi-Band AM FM CB Ham World Radio Receiver
PyroMan6x9x9
  • 150 Answers
SOURCE: cb radio
Not without some serious board modification.
Posted on Sep 15, 2007
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Mechanic688
  • 204 Answers
SOURCE: Bendix King 5102 DPH 138-174 Ham band won't RX
wb6sub, hi don't know if you have the manual for this radio or not, but if not, here is the link for it;
http://www.49ercom.com/pdfs/DPH_Program_manual.pdf
On page 15 it mentions contacting BK for the software to go with your cable.
"2.4 PROGRAMMING BY COMPUTER
Programming a radio from a computer is not covered in this manual. Contact BK Radio for the programming cable, software, and manual required".
http://bkradios.com/thumbnail.asp?offset=0&deep=2&cat_id=202
Hope this helps you out in your search, let us know,,, Mechanic
Posted on Feb 11, 2008
  • 5 Answers
SOURCE: just installed a connex cx 3300hp not sure of
it should be am selector switch on d/a and hi band
Posted on Jul 26, 2010
SOURCE: Grundig Satellit 700 World Receiver. AM bands are dead.
Ist Local Oscillator (PLL) stops working. It's desiged with bare minimum feedback to keep it's output reasonably clean. Removing (De-soldering) the screening box reduces losses, but it's still marginal. Something in the osc. circuit is temperature sensitive, so squirting it with freezer spray - or putting the set in the 'frig will get it going again. Have one like this, "Repaired" - been going for about 5 years and just quit again! If I get any better luck next time, I'll re-post this!
Posted on Jan 27, 2011
I am only able to get 60 watts into a dummy load can anyone give me a good starting point to locate the problem please
What type of CB are you using. FCC limits CB outputs to 4 watts AM and 12 Watts SSB. You must be trying to tune up a liner amp. Need more information
Dec 02, 2016 | Radio Communications
Midland 95 plus
Again another radio with illegal mods to go out of freq bands and FM is not authorized here by the FCC in the USA. I won't provide solutions to anyone with these radipo types. You want more bands, freq.s, power? Go Ham..
May 14, 2014 | Radio Communications
Why can I not receive with nthis antenna
what kind of radio do you have where are you mounting it and is it compatable with your set.A ham antenna may not work with your radio and a ham may not work with a cb antenna.Lot of factors
Apr 28, 2014 | Tram 1198 Glass Mount Cb With Weather-Band...
Am cb radio are out right or wrong
wrong ,there are still am radios .FM is the up and coming thing but there is also the amature band
Jan 01, 2014 | Midland Radio Midland 248 Multi Standard...
Dead key adjust
if you are on the ten meter band then you must be a ham or as they like to be called amature radio operators.being a ham you should have a working knowledge of the radio.if you are not a ham what are you doing with this radio.
Feb 21, 2013 | Galaxy Radios DX29HP 6 Band 10 Meter...
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Ihave a gargeled recive sound
Check the position of the mode selector switch. You may be receiving a SSB (single side band) transmission that is not on the exact same frequency as you or, your radio is in AM or FM mode. You will need to select either USB or LSB (upper or lower side band) and vary the clarifier knob until the sound becomes intelligible. If the sound does not become clear, try the other side band and repeat varying the clarifier knob.
Conversely, if you are in USB or LSB mode and there is a transmission on AM or FM, it will have the same garbled sound. Try changing the mode to AM and the FM. If it does not become clear, it is likely a SSB transmission and you are not on the exact same frequency of the transmission you are hearing. Vary the clarifier knob until it becomes clear - or change to the other side band if needed and try the clairfier again.
The short story is that you must be in the same mode and on the same exact frequency. When in AM or FM, this is less of a problem as these are much more wide banded signals than SSB signals.
The 2990 is really a 50 watt 10 meter amateur radio - but is geared to CBer's as it is easily modified to work in the CB frequency range and the so called "free band" between USA's CB (11 meters) and worldwide amateur 10 meter bands. Be careful transmitting this radio on CB frequencies as it violates FCC rules for power output there - and transmitting in the 28MHz - 29.7MHz requires a valid amateur radio license. Fifty watts on ham frequencies is tiny compared to the 1500 watts permitted. Why not get your ham license (here's how) and leave the "Chicken Band" (and all it entails) behind. You won't miss it!
I hope this helps and good luck!
Apr 12, 2012 | Cobra Radio Communications
After you convert the connex 3400hp from ham to amature, what do you do to tune it in where you can reciever and talk? and also how do you tell what channels are regular,uppers,and lowers?
you will need a frequency counter, to show the channels. 1-40 and the others are allocated as frequencies. there are lists available showing ch1 band A is ??? so forth. there shouldn't be uppers or lower on it its just a AM/FM only radio NO SSB.
and these ARE NOT AMATEUR / HAM radios!!!!!!! these are EXPORTS...
Dec 12, 2010 | Connex 3300 240-Channels Base CB Radio
Midland 75-822 no transmission in FM? why?
there is no transmission on FM because CB is at 26 to 27Mhz on the AM Band and as with your car radio FM starts around 88Mhz. the other reason is tha one one modulates amplatude(AM) slightly to cary the signal, FM modulates the frequincy slightly to carry the transmission.
if you want to talk on FM you might want to become a Amateur "Ham" Radio Operator.
Nov 03, 2010 | Midland 75-822 40-Channels Handheld CB...
147 people viewed this question
 Grubhead
Grubhead
