Question about Dynex DX-L32-10A 32" LCD HDTV
I can turn the tv on and it will cut off after a few minutes
Picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Its not turning on
On the off chance that your TV is having the same problem that mine had, read here for my repair.
-John
May 27, 2008 | Philips 30PW9100D 30" TV
Problem with my Aquos lc32d40u
Your inverter/lamps are bad. Those are only available with the LCD panel as an Assembly, and that is worth more than the TV.
Mar 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Dynex DX-L32-10A 32" LCD HDTV Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
