Question about Copystar CS-2050 All-In-One Printer
How do you cancel printing jobs on a copystar cs-2550 printer
  • 215 Answers
SOURCE: copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Posted on Mar 30, 2009
  • 215 Answers
SOURCE: Copystar cs-2550 drum replacement problems
ok. try this, take the rear cover off, theres quite a few screws. what i'm thinking has happened is you may have pushed the contact for the main corona wire out of place. this board is pretty flimsy. once you have back cover off, the board will be slightly to the right of center as u r looking at machine from rear. i can't recall EXACTLY what board looks like, but if you loosen your drum unit and have someone pull out drum a little and push back in, you will see what and where i am talking about. i'm a tech and had this bite me in the behind one time. will never forget it. hopefully, that will take care of it for you. let me know what you find.
good luck,
razors
krizanto81
  • 65 Answers
SOURCE: how to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Posted on Jun 27, 2009
n25an
  • 622 Answers
SOURCE: Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Posted on Dec 24, 2009
n25an
  • 622 Answers
SOURCE: cs-2550 sofware
goto usa.copystar.com and search in downloads...
Posted on Dec 26, 2009
Cs-2550 sofware
Nov 20, 2009 | Copystar CS-2550 All-In-One Printer
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
I'm try to print a PDF file by Kyocera CS-2550 but after i press print button it's not print and in the kyocera screen I see Print Mode Error
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
Jun 16, 2009 | Copystar CS-2550 All-In-One Printer
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Mar 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-2050 All-In-One Printer Logo
22 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
