Question about Panasonic KX TG6511 Cordless Phone
No dial tone except when using speaker phone
Can not get dial tone when dialing, but if I use the speaker phone I can hear the dial tone
  • 65 Answers
SOURCE: Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Posted on Feb 05, 2008
SOURCE: Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Posted on Oct 10, 2008
cpt_cavman
  • 69 Answers
SOURCE: no dial tone and no incoming voice when press on talk button
might want to check the handset volume .....
Posted on Jun 24, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
  • 37 Answers
SOURCE: My phone says line in use and no dial tone
I also, but my dsl is still functional...
Posted on Oct 27, 2010
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
Can not hear dial tone or hear caller / can hear on speaker call
Most likely that it is the speaker on the handheld part of the phone. Your sound comes from the base itself when you put your current connection on Speaker-Call. So if you cannot hear the dial tone OR the person on the other end unless on "speaker" it's just the handheld and I believe there are places online you can purchase JUST that part if needed.
Oct 19, 2014 | AT&T ATT-1855 Corded Phone
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
I cannot dial out.
The dial may be defective and when you dial it is putting out erronous tones. When the Phone Company heres digits that do not correspond to a legal phone number it will give you a error tone or busy tone. It could be the phone got put on pulse and the line won't recognize the pulses
Dec 28, 2008 | Lands Phones
CHANGE RECORDED MESSAGE
To change the greeting you need to either pick up the phone or press speaker phone then dial *38 then 1 then you will hear a beep/call tone. When you hear that tone record your message/greeting. Once you are finished press the auto dial/store button. If your are satisfied with that message hang up or press speaker phone again to end the call. If you would like to clear the message, then right after you hit auto dial/store you will hear a beep/call tone press 0 to clear or 1 to rerecord.
Dec 08, 2008 | Panasonic KX-T7630 Corded Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Panasonic KX TG6511 Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
