Question about VuPoint Office Equipment & Supplies
Red error light will not turn off
I still can't get my red error light to turn off!
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
  • Needs to be calibrated.
  • See directions.
  • Not very straightforward.
I saw a very dark image in the file that actually saved black. So I recalibrated aiming at a light bulb. Very fuzzy but operational.
Then I did it again on a plain white sheet of paper. Not too good but still better. Now I need a sheet of glaring white.
My 1st mistake was to work on the scanner on a black desktop. I poked the buttons around and calibrated it black!
Posted on Jul 29, 2016
Red error light on vupoint magic wand scanner
Viewpoint scanner manuals are available for download: http://www.vupointsolutions.com/downloads.php?d=manuals
Unfortunately I still can't get my red error light to turn off!
Jun 28, 2012 | VuPoint Office Equipment & Supplies
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
An error message comes on screen when thew xbox 360 is turned on as well as it says up the top (system error .contact xbox customer support )also three red lights flash on and off
This is either an error code or the 3 red lights of death. If it is the 3 red lights, and not an error code, you will be under the extended warranty. If it is an error code, hope u are under your origional warranty.
May 09, 2008 | Video Game Consoles & Games
Xbox360
Sections 1, 3, and 4 are flashing red
- General Hardware Failure
Check the secondary Error Code per the instructions in the section below
THINGS TO TRY
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
Dec 17, 2007 | Microsoft Xbox 360 Console
102 people viewed this question
Top VuPoint Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a VuPoint Office Equipment and Supply Expert? Answer questions, earn points and help others
